ok.. i know this might not be the best place to post this.. but............
ive got one of them victa tornado mowers and when i mow my lawn i do so every few weeks (read: months) so my lawn gets pretty bad.
sometimes my little victa cant handle it and turns off, then ive got to turn it back on and do the old "back and forth, lift" so it doesnt turn off.
anyways i was wondering if i could put 98 octane unleaded into it with maybe 1.25 bottles of the 2 stroke oil to give it more power.
would that work? what other things could i do?
https://www.sau.com.au/forums/topic/98754-more-power-from-my-lawn-mower/
  • Replies 46
Posted Images
Dude , you are not serious , are you ? You ask silly questions you get silly answers.
How is puting 1.25 lt of oil going to give you more power ? How is 98 octane going to give you more power? Its a 2 stroke with a 6 to 1 compression .
Dude... change the spark-plug on it too... sounds like something is overheating and dying on you. But like cars I guess, opening the exhaust, giving it more fresh air, and making sure the spark is right can only help.
98 octane fuel just means it won't pre-detonate under high compression, but a mowers compression probably won't go anywhere near that anyway. If you wanna use it to make your own 2-stroke fuel, go ahead =-]
maybe you should look at your approach.
the lower the mower rides the more work it has to do as the blades are closer to the grass. try setting it to the maximum ride height. this will help do a quick pass to trip the top layer off and it will be less resistance on the blades (like a bigger dump pipe on your gtst). also empty the catcher more often, more grass in the catcher means it bogs up the outlet more (like a non turbelance dump pipe) and this cause more "resistance", so empty as often as possible.
if you are really desperate you could skip the grass catcher completely and wire open the flap door for it, this will allow for minimum resistance and let the grass clear straight away (like a dyno run with the dump/front pipe unbolted)
come on dude, im no dummy.
i know the lawn mower is lacking power, so im just looking at my options in terms of increasing it.
thanks RANDY, helpful info mate.
shut up idiot.
I hope that wasn't directed at me .
I think we can all see who the idiot is . You want to put 1.25 lt of oil in the mower tank , how much do you think the tank holds? Why do you think you mix oil with petrol in a 2 stroke engine ?
Wind out the rpm needle and rev the crap out of it. Take off the air filter. Lean it out some more, but more than likely change the plug.
Or you could sit it there on the spot winding up the revs before you go over a thicker patch :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
