Item:SKYLINE PERFORMANCE PARTS
Contact Details:0417009873
RB25 HEAD
This bolts strait onto the RB30 block without any modifications, will out flow any RB30 head even if it had thousands spent on it. About 80k old, excellent condition, comes with bolts, head bolts lower inlet manifold, cam gears crank angle sensor etc.
$650 more info 0417009873
RB25 EXHAUST MANIFOLD
Standard exhaust manifold in excellent condition, it's actually proven that with a std exhaust manifold it's not worth replacing with a stainless unit in terms of power. Std version is split pulse for faster turbo spool.
$200 more info 0417009873
TURBONETICS WASTEGATE (Brand new!)
Brand new 32mm Deltagate is rated at 550hp, its compact, very high quality and very light. Comes with gaskets and flanges. Never used.
$400 more info 0417009873
FUEL INJECTORS 550cc X 6
Perfect injectors for a fast VL, GTR or GTS. Were in a 300kw GTR, with plenty of duty cycle left. Excellent condition. (x 6) $450 More info 0417009873
cc / 5.2 x no of cyl = Hp rating
550 / 5.2 x 6 = 634hp @ Engine
SPITFIRE COILS
For big spark in a high horsepower GTR or GTS-T. Worth $1000, excellent condition sell $500, 1 year old. More info 0417009873
SARD REGULATOR (Brand new!)
Most stable fuel pressure regulator on the market, good for 800hp plus. Brand new suitable for any vehicle.
MALPASSI REGULATOR (FUEL) Black
Was on GTR (300kw), this is the high pressure version with gauge. 1 1/2 years old, excellent condition. Will suit any vehicle.
$150 more info 0417009873
MICROTECH LTX - 12
Plug in computer for GTR skyline R32. Tuned with plug in adapter to std loom. Cheapest after market alternative worth $1600 selling for $800, save money on tuning costs, most of tuning is already done as its straight of a 300kw GTR.
GTR R32 PWR INTERCOOLER
Bolts straight on the R32 GTR or GTS, 3'' pips in and out, polished, excellent condition. Heaps more flow than std intercooler a hence much high horse power rating, could be used on 400kw plus GTR. Worth $1500 selling $700.
COMMETIC METAL HEAD GASKET (Brand new!)
Suit any high powered RB26, RB25, RB30 engine. Eliminates the use of copper head gaskets that always leak and no o-rings required in the black, brand new, good for 40psi plus. $220 more info 0417009873
GTR RB26 PLENUM (JUN COPY)
Rated for 800hp plus application c unwelded so it could be cleaned up, dedagged inside, infinit throttle flange. For a single throttle application big hp RB26 GTR. Brand new never used. $1000 more info 0417009873
NISSAN INFINITI THROTTLE BODY (90mm) Q45
This is off the Q45 Nissan V8. Good for single throttle plenum for the GTR, SR20, skylines etc. Excellent condition, $400 more info 0417009873
FALCON XF THROTTLE BODY
68mm throttle body for anything up to a 1000hp. Used on a VL commodore that run in the 8 sec bracket, complete with plenum flange and T.P.S.
$100 more info 0417009873
R32 GTR SKYLINE AIR CON
Air conditioning compressor and condenser core, excellent condition.
Condensor core $100
Compressor $250 more info 0417009873
Edited by Kyle
https://www.sau.com.au/forums/topic/98833-skyline-high-performance-parts/
Im sorry everyone but i dont have anything to do with the actual sale of the parts i just put them on the site. So anybody with any offers, questions, private messages etc please call the number given as i can not answer anything. Thankyou
  • 4 weeks later...
    • I found a supplier for an arm in NZ. https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-rh-side?srsltid=AfmBOopMdfCFDc_8yVZZ9kq5nIngPHRTBzUU8v4SAptJaRO52Wjs0bC6 I looked closely at the photo of that one and the Z1 arm, and it's the same bloody arm. Scratches all match in the photo 😂 How hard is it to change that joint? Also they seem to be listing two options https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-balljoint-rh-side?_pos=1&_sid=229acde44&_ss=r And now I have no idea what size I'd need yay
    • Ill review it again, from memory when I first saw some of Trailer Park Boys I wasn't a huge fan. I ended up at Letter Kenny after watching Shoresy, which is a bit ass backward, ha ha
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
