I got my CA18DET and gearbox delivered from Sydney to Melbourne. As long as the engine is loaded onto a pellet the company I used charged $120 to pick up and deliver to my workshop in melb.
Always use private couriers, they're so much cheaper and will bend over backwards for your business (like organising a truck with a crane to pick up pellet if there's no loading facilities etc).
You might want to try putting it on a pallet instead... I wouldn't trust a pellet to support the weight of a motor. :)
(before i get flamed for my pedantics, funky started it!)
thanx peoplz lucky for me i got two jobs and one of em has forklift access... and yes private couriers are the way to go.
i also rang up some workshops and and spare parts shops and asked if they could recommend any1... so far the cheapest quote i got was $135
now that thats sorted, were the hell do u get this wire strap that i keep hearing about?
it was Aussie wide Logistics that did mine
0404 055 083
Easy guys to talk to and negociate with. Based in Melbourne, but specialise in interstate deliveries.
Otherwise you could try http://www.busfreight.com.au but I dunno if they do engines.
Transport Company I work for could possibly do it but that price of $135 sounds very good. They would also only transport it from Dandenong to Wetherill Park as they dont normally touch anything other than chilled goods.
R31Nismoid hahahahaha u dont no shit, brescisni didnt build PANNIC, AVO did.... wen Mille (the owner) sold his car he sold it to Danny Besciani they tunned it up slightly and claimed it as their own. then they built up PLATNM with almost the same mods. they learned a lot from PANNIC and apply those techniques and ideas from Terry Wilson (at, yep u guesseed it chump, AVO!!) on their customer cars.
... but then y do i feel that u wont absorb much of this??
and FUNKEYMONKEY busfrieght r good people they do all my small interstate frieghting, but they wont do an engine... the logistics company sounds good tho
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
