Thanks for the info , sounds like the 4wd would be a great solution to the lack of traction I have off the line. I took the car to the drags and the best I could do is a 14.2 with heaps of wheelspin, the 60ft time was shocking.
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1806732
AWD cef is pretty much the exact same as an R32 GTS4. Diff front, rear and ratios are also identical between the two. You can't mix and match manuals with autos though due to different diff ratios (well you can, but you need to make sure front and rears are the same).
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1806749
I did spot a factory special with RB26 and full GTR running gear , not sure if it was Autech model, I think it was a 96.
Pity no one complies the late models, I try to track down some pics.
Fuark.
That'd be worth it under SEVS no?
Can you just pick up the running gear into a RWD cefiro? I would have thought a AWD cefiro would have a different floor pan no?
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1811644
it does indeed, different chassis structure. I haven't heard of this autech RB26DETT ceffy till just then, but it won't be eligible under SEVS for sure (just like the Autech 4 door R33 GTR's and S15 convertibles aren't, until they are tested).
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1811672
  • 1 month later...
I'm plan to install the 4wd to my '89 A31 & will be RB26dett BUT dont know which rear assy to choose & other part. Recently I'm using RB25det S2 .
My idea if mod this RB25det engine with rwd, I will facing the traction problem.
Any idea & advise please
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1897012
mmmmmm autech 4 door R33 GTR........drool.
https://www.sau.com.au/forums/topic/99153-cefiro-4wd/#findComment-1917828
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
