I'm about to go out and murder some little local pr*cks.
My holiday/ fishing vehicle (2005 hilux SR dual cab) loaded up with expensive fishing gear and hunting equipements was half packed for Friday and I did the cardinal sin, by taking it to work to get tinting done.
Well the little bastards smashed the driver side window and mangle the rear right door trying to openin the ute up, in the process they threw a brick through the window so hard that it smashed the centre console and destroyed the door trim on the otherside.
The police didn't even wanted to know about it after I waited for nearly 2 hrs at the local cop shop.
Now I finished my rant, anyone see any young kids running around with VERY expesive binnoculars/scope please contact me,a big reward is offered.
https://www.sau.com.au/forums/topic/99230-vehicle-broken-into/
OOps, sorry, the area was Calamvale. I suspect the gear would be floating around Browns plains/Crestmead area, as I've seen a few youngins walking towards that direction this morning.
More than likely. Prob the stupid barsard round here that got pulled over trying to steal a bobcat the other day.
Hope they are caught, and you get most if not all your gear back.
Out of interest, insureance???
even if u got insurence most of em only cover upto $300 of gear inside the car.... unless u want to pay more for your insurence :)
Yes the car was insured, but personal effects is $300 max, DOH!!
To make matter worse, Toyota haven't got one of those side glass in stock, and I sat on a glass splinter yesterday which will need the attention of my good looking female Dr.
So the trip out to St. George is off, oh well I be doing somethig else this Xmas.
yeah I know with the insurance been there done that lost over $1000 worth of gear out of my old surf, makes u really want to find the turd that did it & snap there fingers off one segment @ a time
hope u still have a good xmas bud B)
Sorry to here that champ
in a way xmas is the shitest time of year
brak ins
angry cusumers
i had my laser broken in to last friday
$6000 worth of stuff gone so i feel for u mate and 2 days later i put my skyline into my brick piler doen $2000 damage come in 3s
james
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
