A full motor is everything, you would expect inlet manifold/plenum and exhaust manifold attached, and maybe a the wiring loom
Long motor is the complete motor with head no manifolds
Short motor is the bottom end, no head attached....so sump, block, crank, rods, pistons etc etc only.
You only need the short motor for an rb30 conversion since you are going to put a decent head on it instead of the SOHC
There are a couple of different types of Rb30 engines. One is good for the conversion the other not.
One from a wrecker will not be rebuilt so you are taking a bit of a gamble.
Short motor means no head. An R32 head I dont think will bolt to the rb30 bottom end...
have rb25 head machined to fit rb30, mild porting and bigger than usual springs - $900 take it away
may seem like a bit, but that is machined AND ported already done for you
then just sell your stocker rb25 head on forums.
also have rb30 block. from series 2 vl calais - correct block for rb30det conversion. has 160,000kms on it - clean block. 200 for block ready to go.
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
