A full motor is everything, you would expect inlet manifold/plenum and exhaust manifold attached, and maybe a the wiring loom
Long motor is the complete motor with head no manifolds
Short motor is the bottom end, no head attached....so sump, block, crank, rods, pistons etc etc only.
You only need the short motor for an rb30 conversion since you are going to put a decent head on it instead of the SOHC
There are a couple of different types of Rb30 engines. One is good for the conversion the other not.
One from a wrecker will not be rebuilt so you are taking a bit of a gamble.
Short motor means no head. An R32 head I dont think will bolt to the rb30 bottom end...
have rb25 head machined to fit rb30, mild porting and bigger than usual springs - $900 take it away
may seem like a bit, but that is machined AND ported already done for you
then just sell your stocker rb25 head on forums.
also have rb30 block. from series 2 vl calais - correct block for rb30det conversion. has 160,000kms on it - clean block. 200 for block ready to go.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
