can someone tell me the weight of thair skyline r33 on the rego papers mine says 1520 and my sons is 1380 but thay are both the same car 96 mod the only dif is mine has abs and that dont come in at 140kg so if someone could help me out that would be great
https://www.sau.com.au/forums/topic/99348-tare-weight-of-a-r33/
when it was complied it should have been weighed. that's what they put down as the weight for rego. that's unfortunate for you as being over 1500kgs means you are paying more rego to the tune of about $100 per year.
Beer baron, thats why i got mine under 1500 kg (A 34 gtr ) , all 33 gts's are well bellow 1500 , around 1380 kg .
You can go to a public weigh bridge get aticket and take it to RTA so they can correct it .
Hey mate. I had the exact same problem with my R33 sedan - it said 1570kg on the papers.
What I had to do was go to a workshop who does blue slips and get an adjustment of vehicle records form ($22). The bloke I went to accepted an extract from the workshop manual that quoted the weight. He put the highest weight of the quoted sedans. 1420kg even though mine may not have had all the features but it brough it down to the lower bracket and I was happy.
If your blue slip guy doesnt accept that you will need a weighbridge ticket (about $30) aswell.
yup, same here. I have my GTR down as 1420. They tried to tell me the standard weight was 1520 and that 1420 was for a non-turbo GTS. I just said, look at my blue slip. 1420. done and dusted :P
