Buying A Camera
Agreed, wooden ramps can’t go wrong. Or buy low profile ramps ie. gktech
By RB25inside · Posted
Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
