hey guys i just bought a std r32 gtst (only pod n 3 inch exhaust) n a mechanic said its been boosted well above 7psi n i dont have a boost controler to turn it down, even on low trottle the boost runs very quick to show reading over past the factory boost guage of 7psi, if im runnin this high boost for long,
a) what damage could it be doin to my engine n turbo since i dont have a front mount or any other mods for sufficient airflow cooling for the boost level (prob 10/11 psi)? if so what would be a safe boost level without puttin a strain on the engine without the frontmount?
B) what would be the cheapest n best way to fix the problem? (maybe turn the boost back down with a manual boost controller)
c) would a bleed valve help?
d) i also get 300km on a 42l tank with only some racing, is this decent?
thanks guys for any help you can give me.
https://www.sau.com.au/forums/topic/99407-plz-help-too-much-boost/
If its showing 7 on the factory guage, it means its running over 14psi as the factory guage uses different units to psi.
The only way it can run more then standard boost is if the wastegate actuator has been changed, its stuck partially closed, or it has a bleed hole or split in the hose between wastegate actuator and the turbo compressor cover.
Check that first.
11-13psi is FACTORY :lol:
No its not
Factory is about 7psi, with a full 3inch exhaust and pod it will creep to 10-13 though, I know mine did.
Theres no way to turn it back down without getting a different spring. A boost controller will only allow you to set it higher then what you currently have. Id just take it easy on the hot days and get a FMIC so it doesnt cook the air. If its really going up to 14psi Id get the spring/actuator checked as somethings wrong there and it'll kill the turbo pretty quick smart and really cook the air.
does it still run good?
if so get a turbo timer and enjoy it i say.
With the standard turbo and intercooler anymore then 12psi will just cook the air making the engine more likely to ping (bad) and not give any power increase, I wouldnt recommend leaving it like that with summer coming up.
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
