I was wondering how the RB20DET gearbox was designed.
I have rebuilt 6 or 7 single rail gearboxes that are used behind a ford 250 6cyclinder.
They basically had a main shaft with gears on it that had a front input shaft bearing and a bearing at the rear.
THen there was the lay shaft that was one big set of gears they were basically one solid piece with a metal bar running through the center that required hundreds of tinny little roller bearings that you had to first stick on with grease then slide in to the layshaft.
It is very fiddly but worth it as a rebuild only costs around $120.
Inc. all new syncro's main bearings and roller bearings.
So I am looking at rebuilding my rb20det gearbox which i wil be able to match up some heavy duty bearings from CBC (hopefully)
BUT i havn't rebuilt a 5 speed so i was wondering if there was much of a design difference between the old 4 speed and the 5 speed.
Anyone?????
https://www.sau.com.au/forums/topic/996-rb20det-gearbox-design/
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
