ah right right, do gtr injectors fit in the std rb25 fuel setup and would i need an ecu if i upgrade them? i know that with the rb30's its u haveto change the ecu if u have the injectors. But im not too sure on the rb25 ecu.
Edited by LTHLRB
According to HPI stock r33 injectors are only 370cc/min and as such run out of flow at around 200rwkw.
really???
i have about 200rwkw with standard injectors and the are nowhere near their max duty cycle...
i think they are only at around 70%...i thought 250rwkw was achievable with standard injectors??
also dont believe everything you read in magazines, rather talk to people with experience...
aren't SR20 injectors side feed as well?
Yes, SR20 injectors are also side feed. You will need to buy larger Sard/Nismo/Bosch/Denso injectors if you want an upgrade as there is really no standard injectors that are an easy side feed upgrade.
I thought I read S15 injectors (side-feed) were a straight fit on R33 GTST? They aren't 550cc but they are higher than r33 std 370cc, maybe 470?
Also GTI-R SR20 injectors are top-feed and some side-feed SR20 injectors are only 370cc so same as R33, so if you go sr20 make sure you get the right ones.
Well how much power are you chasing?
If Jetdat is right then you can get 250rwkw with std injectors.
The most i can get in standard from, standard being ecu, bottem end, cams. Maybe around 200 - 250 rwkw. Ultimately in the long run around 300 350 rwkw using a 35/40 and maybe rb30 bottem end rebuilt with steel rods and forged pistons and a good set of cams.
Edited by LTHLRB
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
