  • Replies 51
Here's the one I submitted over 4 months ago.... Didn't get much feedback at all so I gave up..
Performance Enhacenments to come (time permitting) :
http://brf.homelinux.com/images/flyer.pdf
so b-man, the battle is on. do we need a poll, or are there other good alternatives to include first.
Dino, yours was great, but the url was wrong so it cant be accepted. And Ben, I like that fact that yours had headlights and taillights at the same time. very witty
These Weapons of Mass Destruction cannot be displayed
The weapons you are looking for are currently unavailable. The country might be experiencing technical difficulties, or you may need to adjust your weapons inspectors mandate.
Please try the following:
Click the Regime change button, or try again later.
If you are George Bush and typed the country's name in the address bar, make sure that it is spelled correctly. (IRAQ).
To check your weapons inspector settings, click the UN menu, and then click Weapons Inspector Options. On the Security Council tab, click Consensus. The settings should match those provided by your government or NATO.
If the Security Council has enabled it, The United States of America can examine your country and automatically discover Weapons of Mass Destruction.
If you would like to use the CIA to try and discover them,
click Detect weapons
Some countries require 128 thousand troops to liberate them. Click the Panic menu and then click About US foreign policy to determine what regime they will install.
If you are an Old European Country trying to protect your interests, make sure your options are left wide open as long as possible. Click the Tools menu, and then click on League of Nations. On the Advanced tab, scroll to the Head in the Sand section and check settings for your exports to Iraq.
Click the Bomb button if you are Donald Rumsfeld.
Cannot find weapons or CIA Error
Iraqi Explorer
BTW, when is this thread moving to wasteland?
I didn't feel like going to bed tonight so I decided to make a flyer, not sure if it tops the previous effort though...
I was thinking of using an R34 but couldn't find a pic I could use. I can change the text and pic if need be. This has been optimised in order to be able to atach it, I can provide a higher quality one if needed.
Let me know what you think.
Matt
OK,
So we have some good ideas... what we need is to set wome criteria... try thinking about what the club is about... what we do and also perhaps include some sponsors of the club...
But I do like B-mans and Funkbrothers!
Lets se if we can bring this thread back from the wasteland... now... how do I ban Duncan???
Dan.
  • 1 month later...
Bumpity bump bump bump -
Oh and one more B U M P
because this has been hanging around like a bad smell for WAY TO LONG.
Someone make a damn decision ! I don't care who's banner wins - I'll withdraw my entry if it makes it easier... Damn it.
We as a club should - sorry, NEED to have these flyers so we can get more members.
FFS -
PS - We don't really need a club meeting to resolve this do we ??? What wrong with using the forums as a medium to get this decision made ??
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
