Dash Lights Wont Work....help
proRB88
 Share
Hey guys/girls,
2day I installed a head unit into my R33 and when I finished I checked to see if everything still worked. Unfortunately for me the dash lights stopped working, but the headlights still work.
At first I thought it was a fuse. So I started to check all the fuses (inside the cabin) with my test light but all of them were okay (they all made the test light turn on).
Then I thought it was the LEDS so I pulled them out and when over to my 12V drill battery, and tested them out. They were fine, they all lit up
Then I thought okay ill just reverse everything I did so I cut all the wires to the head unit and tried them again. Once again still nothing.
The thing I found weird was that I got rid of that beep when you leave your lights on or the key in the ignition (I have not a clue when this happened); I only noticed this because the car went dead when I forgot the lights on.
Can anyone please help me I really don’t think it’s going to be much fun driving around with no dash lights on!!!!
Regards Vlad
Hi,
I still think there is a fuse blown, when checking your fuses did you have the park lights on? You need to turn them on first to check for dash light fuses that is the only time they will make your test light turn on.
Try this then get back to me...
Leon
Hi,
Leon
Hey Leon
i tried testing the fusess insid ehte cabin when the lights were on the on position, but still no blown fuse ill try agian, could it be a fuse somewhere else in the car?
Also does any1 have the fuse box diagram so i can see where to look coz everything is in Jap...
Vlad
Also check that your dimmer is plugged in. They are normally fitted here in AU at the time of compliance as many imports do not have a dimmer circuit, most of them are done dodgelly. If the dimmer is not plugged in there is an open circuit on the dash lights.
Also tell me if the outside park lights are come on and if you here any clicking under the dash when your turn on park lights.
two more panels in that car. one outside in the enginebay and one in the boot. there IS a blown fuse in there.
leon,
depends when the car landed if it has a dimmer of not. if it was done after 2002 then it will not have one.
leon,
Nah there is no dimmer that i could see anywhere, i remember looking for one when i fist got the car and didnt find one.
Aight thats one step forward (i hope)the parkers dont come on, and there is no clicking sound either....
I'm about 80% sure its a fuse but can i get told which fuse to look at or replace!!!
Aight guy
just found the problem, it was the fuse in the boot third one from the end (10amp),
NOTE:
make sure when installing you own stuff to make sure the earth you are wiring up is an earth and not a illumination:))
thank you guys for your help
I had this happen to me to. It ended up being the third fuse in the boot aswell, but you probebly didnt notice that this not only controls your dash lights but also your rear tail lights, I didnt even know they werent working.
Just incase anyone with a R34 does this. I blew mine aswell.
Fuse located in the enginebay fuse box.
Forgot which one though.. But its there :blink:
Dashlights and Rear Park's would work..
MRXTCZ
  • 5 years later...
extra advice for r34 drivers with this problem, i done the same thing, replaced my stock head unit and then was constantly blowing the tail light fuse everytime i had the accessories on (stereo running) when i tried to turn my lights on, found out my problem was a ground wire overload, so if u take the wire from the back of your unit and ground it in a different spot it should be fine, worked for me! :D
 Share
    • don't do. Fricken typos. Make me look like the sheeple.
    • I could show you guys photos of wrap having been removed properly, and where the wrap was removed, paint underneath is perfect. Sections of the vehicle didn't have wrap on it, and in those areas, the paint work is destroyed because of how long it had been sitting in the hot QLD sun for many many many years. Wrap even still looked decent. Good quality wrap, and removing it properly shouldn't rip off the paint work, unless the paintwork was already shot to pieces before hand.
    • Any write ups on replacing the window motor?  I've never messed with them (or window regulators) before.   Ever since I've had the car, the driver window would roll down just fine, but most often I'd have the try a few times to get it to go up.  As soon as it started to go up, it always goes up smoothly and quietly.  Seemed like a bad switch.  But now, its stuck in the fully down position and won't come back up.  I get =12/-12V coming out of the relay/amp when pressing the switch up/down.  So the switch and amp are working.  Just a bad motor.  I've also applied 12V directly to the motor and nada.   Any help on replacing the motor?  Can the glass and regulator stay in, and only replace the motor?  Or not possible?  Thanks!!!
    • You are wrong. That's just Whiteline going along with the incorrect slanguage of the sheeple userbase. They are only correctly known as anti-roll bars. They are only incorrectly known as swaybars. They do do anything to prevent "sway". The swaybars that are fitted to trailler hitches do prevent sway. In the trailer. And they do not look like anti-roll bars. So, take your incorrect infopinion away.
