  • Replies 116
  • 3 weeks later...
the standard AFM sits inside the airbox, but u need the adapter from the AFM for your pod, if thats the one your talking about.
As for the pod, i know the K&N fits perfectly, not sure on others as i havent tried them , but if they are a similiar size they will fit in the box, as far as i know teh apexi one fits in with no problems .
if the hks is a mushroom pod, i think it may be to big to fit it.
NOTE: To anyone ive sold one to can u list your pod, as a refrence to others
Edited by mr_crust
Yeah the HKS one is a mushroom pod, it bolts on directly to the AFM. So if the AFM sits inside the shield then the pod would sit in there as well... providing the HKS one fits in the first place. Might just convince me to get that Apexi one! :teehee:
  • 1 month later...
Received mine today, putting it in tonight. I also grabbed 2meters of rubber edging for like $6 and edged any part that may come in contact with the paint. I'm also putting in heat shield foam on the inside. Good quality product and great value considering what others are charging.
Looks good Dan, and i might actually put that foam stuff in my own box and see how it goes.
Xizor: Ive got a few more made up in my spare time, but never really re-advertised them, but for anyone intrested i still have a few
  • 4 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
Ă—
Ă—
