i know today is extremely hot (42-43 degrees)
but i think my car has a problem
normal driving, the car goes up to around 110 degrees (quite quickly) on the r34 temp gauge (dunno how accurate it is but it has never went past 90 before)
there is VERY hot air blowing out under the car and towards the front of the driver side bumper
air coming out the exhaust is hotter than usual and seems to burn
also, my air-cond does not work and only blows out hot/warm air
any suggestions?
https://www.sau.com.au/forums/topic/100273-heating-problems-help/
Coolant should start boiling at around 120degree's providing the system is holding pressure (no leaks) and the correct coolant mix/ratio has been used. Its the oil temp at these coolant temps that is the worry. :S
Check the fan's viscous clutch.
Chances are its stuffed. :P
If its not check the thermostat then radiator.
Providing your running decent coolant with the correct mix it shouldn't boil until around 120degree's. Its the high oil temp that follows the high coolant temp that is the worry.
A couple ways you can test the fan.
When stone cold... star the car.. you should hear the fan roar for 15seconds or so. If it doesn't then its stuffed. :(
Once warm... Pop the bonnet then turn the car off while you watch the fan spin.. As the motor stops the fan should follow, it should not continue spinning freely. If it does then its stuffed. :(
I have noticed with mine it appears the car disengages the a/c once engine temps get too high. Unsure if its just a coincidence or if its really the case. Mine appears to do this when I've had cooling issues in the past.
Mine often hits 90degree's with the a/c on in traffic on a hot day.
The genuine thermostates make the car run a little warmer.
Aftermarket items (from supercrap and the like) open earlier and wider causing the car to no longer reach operating temp within 2km's and also it never really hits the 'correct' operating temp, being ~82-85degree's.
85degree's is apparently the optimal temp for fuel economy.
I'm in the process of dropping a nice 14" thermo fan in front of the A/C condensor to replace the std 12". Should help on those hot days sitting in a traffic jam as the stock fan draws stuff all air at 800rpm. :blink:
The proflow thermo's from Ebay are cheap and work well. Flow more than the davis.
On these hot days I've also noticed the pwr steer gets a little heavy and fluid appears to blow out the top of the reservoir a little, looks like a slight seep around the edge of the cap. The answer is to fit a power steering cooler. easy done many aus cars have them for this reason.
Head to the local track and you will find the pwr steer fluid appears to boil over, some I know of have placed a sock over it to prevent too much fluid going everywhere.
Edited by Cubes
thanks cubes
will test out the cold start and warm test tomorrow (neighbours may not appreciate me turning the car on right now lol)
i noticed today that there seemed to be ALOT more air blowing from under the car..
also tried spinning the fan when the car was off and the fan moved from one blade to another with the flick of a finger, is this the normal distance?
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
