Idle At 2000rpm
33SOM
 Share
Nah trust me i pulled it off and the spring was attached. it looked exactly the same as that.
What i meant was the flap moves freely with the spring. although my spring looks smaller than that one.
Today I blocked off were the aac and air reg go onto the plenum and there hoses (exactly the same way an aftermarket plenum is setup) and it still did its crazy idle.
hey 33SOM,
i have been having the same problem with my r33 for the last few weeks.
Sometimes it will idle normal then other days its around 1500 to 2000rpm.
i have found with him that if its idle is normal and i give it a good bang, it will then go up to the high idle, but if i drive normal shift at like 2500rpm it seems to be fine.
when i get off my ass i will try everything u have done
The idle isnt the greatest at the best of times but when it is good it is pretty stable. I havnt seen limiter since friday and the idle is still a mess.
Looks like a problem that occurs when ya have a power fc installed
haha
i had mine installed in october
november, i started noticing the idle repetitively going from 500 to 1500
not the best look when you have stopped at the intersection.
i'm am in the midths of looking into it .
my AFM is not the cleanest one i have seen, and going to clean my panel filter aswell .
i will clean the AAC valve aswell, and replacing my fuel pump with a bosch 040 which i have recently purchased. ( Nothing to do with the idle but anyway).
I will also check the spring on the throttle butterfly, the "cold idle valve thingo" and the TPS, whateva that is.
After i have mucked around with these possible solutions, and i know then that its not them and they are clean. i'll take it to, "hopefully" a person that knows what it might be, and fix it
One good point from this, is my car seems to run quite smoothly when driven, like an idiot (not on the streets of course) or like a granny.
Just the idle is the problem
I also have the problem of turning my car on.... sometimes
it decides to just click and not start, eventually it will start
im guessing my starter motor is rooted, or fuel pump.
(Replacing fuel pump soon)
Any advice as with the other two fellow ppl with the same fortunate problem.
Would be much appreciated and less stress on me
Thanks
Thanks
You have an alarm? A dodgy immobiliser caused that once for me.
i have a mongoose alarm
it did work properly.. once
at the moment, when i press the button to lock the door
it doesnt lock, but does arm the car if you do open it, and the alarm will go off.
i actually have to press the button to arm then use the key to lock the door. Its very fun, but i do atleast know the doors locked.
I have a new motor to put it, will be fixed soon
i will also check the immobiliser wiring and make sure it works properly
THanks for that.
 Share
