I came back from queensland about a month ago spent two weeks over there partying it up for new years eve with my mates (very messy photos) I was impressed by the imports there every one that went past had the biggest loudest blow off valve haha it started to make me homesick for my car :starwars: every skyline that went past im like ahhhhhh look at that - - - - oh yeah i own one of those. You kinda forget when you have to catch the stupid bus everywhere.
https://www.sau.com.au/forums/topic/10032-queensland/#findComment-156722
haha half of them me and my mate cant remember taking!! It was an extremely messy new years eve!! Ive been meaning to scan them to send them to the guys from melb we were partying with just havent got my ass into gear yet.
Queensland rocks to visit wouldnt wanna live there tho.
https://www.sau.com.au/forums/topic/10032-queensland/#findComment-156852
yeah they were quite common there which takes a little bit of the specialness out of them - there about as common there as a commodore here. They are very ricey there tho - but i guess u gotta do everything u can to make them stand out from the other 19 u see a day :P
https://www.sau.com.au/forums/topic/10032-queensland/#findComment-157062
Hmmmm you make Queensland sound so good but it seems you like Havelock Street in West Perth a bit better as every day as i leave Dumas house there is a nice black Gtst with NIZMO numberplate.... and with the best sticker of all time.... "NO THIS IS NOT MY BOYFRIENDS!" HAHAHAH!! I LOVE IT!!
I did get a bit carsick myself whilst i was in sydney though. I saw a lot of nice cars over there then i missed my car and wished i could have been in it.
Are the roads in Queensland quality OK are they as good as ours.. i always thought our roads were bad then i went to Parammatta road in Sydney then realised my front spoiler wouldn't last 5 mins on that road!!
foshan: does the company have a website at all where we can check out there stock?
https://www.sau.com.au/forums/topic/10032-queensland/#findComment-164615
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
