ah sweet as. yeah i think i do rember you. yeah my car is sitting at midas right now. dean is just finishing off the extractors today.
yeah you might see it out the hutt on thursday. i will have been for a long drive before then to start the run in as i will probly thrash it at some stage being around the skyline guys as they will all want to see what it can do.. lol
good to hear that your car is running again :P
  • Replies 99
Posted Images
yeah wazz i know thats the worst thing to do. but also nanaing it is just as bad. i have planned out my first trip in the car. will involve alot of accelerating and decelerationg and change of load as i will be going over hills etc.
i think i can have the 1,000 run in ks done in a week and a bit. if i have the time.
yeah definatly will try to get some audio of it. probly will need to change the rear muffler from the stock turbo one im running now. seems to have good flow and is nice and quite.. just a little ratly i think.
fuel consumption
hwy driving 9.5 ltr /100 km and better ( 10.6 km / ltr )
city driving 10.8ltr /100 km  (9.2 km / ltr )
Gawd damn.... Doesn't appear to be any difference in fuel economy between turbo and N/A.
I've only just had gtr injectors and a new genuine 02 sensor dropped in, trimmed back the pfc fuel correction to 58.5%, instantly it began getting 11.6L/100km's.
Had it all tuned up and now gets a nice solid 10.6L/100km's of city driving.
I'm pretty much just cruising around 90% of the time, occasionally I give it a little squirt that has it turning the rear's easily in second gear. :)
So it is driven fairly easy.
Prior the old crappy 260cc injectors were causing hard starts and slight flat spots on the tip of the accelerator pedal. Fuel economy was wofull. ~14L/100km's.
On the stock ecu when the injectors were ok it was managing ~11.1L/100km's.
cheers for the advice. especialy cus im planning on starting the car on thurs. will definatly be an interesting time. have to rember to keep using the brakes. not the engine as i usualy do.
yeah the fuel figures will be interesting to see how it all pans out.
ok well i got the car back yesterday. iv had a few little problems. all but one i have delt with now.
the car cranks, has fuel, injectors are working, not sure about the coils yet.
but the problem is the ECU is coming up with the error code 34. so that is about the knock sencers. that doesnt suprise me as the loom was cut on only the knock sencers. but i have solderd it up and still no luck. im really frustrated as no body knows what to do to fix it.
i have attachd a pic of what im talking about. the brown wire has the clear wire inside. but it has silver wire on top so i dont get how it works and what the silver wire is there for as its not grounded on anything. and it just stops abruptly(checked that on the rb20e knock sencer wire.)
she lives!!
oh how good it feels to have power :D even tho i can only rev to 4000rpm its still damn fun. well for the 5mins i drove it.. oh and the mean grunty sound even tho it only has a stock turbo muffer on there.
then i found a coolant leak under the front of the inlet manifold. so thats off now. gota replace the gasket and the front stud as the thread is munted. but that should be done tomorow.
dyno is in 2weeks(18th march) and on the 19th im taking part in some 1/8th mile drags.
oh its starting to get exciting. mmm rb30 goodness :)
yeah i used to have a dirty old rb20e. the jump is massive. i might try get a drive in one of my mates gts25 just for comparasion. or let him take it for a spin to compare.
im keen to see how the dyno gos to see what the torque and kw are.
it will definatly be drivable round town easy. now i just need to get the inlet manifold on. check for leaks then i can start driving again :)
Hey I was thinking of doing this conversion on my R31 since DOHC is always better than SOHC, but I just want to know if all RB25's have VVT and whether you can run it without the VVT? Also do you need to run it from the RB25 ECU or can you still use the RB30 ECU?
read the r33 rb30 thread.
r32 heads bolt stright on. that thread is in force induction.
you can make them run with out vvt. just change the inlet cam. but you still have to run external oil feed and drain.
ok heres some sad news :P
sounds like my rb30 has screwd the big end bearing after only 20km of driving. yeah its worse then a rotor...
the reason why is the engine lost all its oil out of the front of the engine. presumably around the crank oil seal. so it should be fixed under waranty. argh stupid engine builders!!
so ill probly wont be able to dyno the car or take it to the 1/8th mile drags as it probly wont be fixed in time :(
all i can say is the little bit of driving i did today was freaking awesome. i cant wait to have it back and running. it sounds so nice too :O
If you mean the one stickied at the top, that thing has 166 pages! Can anyone just tell me if the RB25DE ecu is needed to run the RB30DE. I'm assuming so since it is DOHC and it has the cam profiles in it.
if your going to not use the vvt you can use a rb25de ecu outa a r32. im using vvt and i was running a stock rb25de ecu from a r33. bear in mind you will need the right loom for the ecu.
download this pdf to find out everything you need to know
http://www.geocities.com/r32_jjc/
Lol forgot about the loom. Now I'm not so sure if I want to do the DOHC conversion since there'll be a lot of wiring involved. Think I might just go down the RB30ET route.
Guess it depends on how much wiring there is to do and how hard it's going to be and also how long the car will be off the road.
Is there actually much work involved in having the VVT?
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
