  • Replies 99
Posted Images
yeah they are cheep as chips. mine cost me $100 but nah iv spent enough on the internals of that motor getting it ballanced, pistons swapped over etc.
the engine place should fix it under warranty due to there screw up and all the oil pissing outa the crank seal. it must have pissed out like 4-4.5ltrs of oil in 10km
im used to not having a car by now. its been like 3 and a half weeks now. whats another week or 2?
as long as i have it back in time for the drags im happy as iv paid the non refundable $$ for it :)
cold fusion:
the wiring isnt that much hastle. well for me it wasnt too bad. running the loom isnt hard. in my r33 there was 2 or 3 wires that didnt match that stopped the car from starting. an auto sparky should be able to have it sorted for like 400max?
there isnt that much work in having vvt. well i suppose there is. welding up the front oil gallary, runing an external oil feed. thats the main bit of work. im pretty sure thats all detaild in to the rb30 pdf file.
dondesoto has a rb30de running vvt in a r31. have a look at post 8 on page one.
I think the wiring in my case will be more difficult as it will be going into an R31 which probably means most of the wiring is different. Welding the gallery shouldn't be too hard for me, the taps might be a little harder. Will probably need dondesoto's opinion on this.
$100 for the block is really cheap. Didn't know you could get them for that much. Where would you get just the bottom end (block, pistons, rods, crank, sump)? Wreckers? Engine reconditioners?
Thanks for all the help guys.
i got mine from a wreakers. my $100 was for a short block. i was lucky and i got one with the tubo fittings(incase i ever want to go turbo)
the wiring is workable as proven by dondesoto.
the welding is alloy as you have to weld the head. not the block.
send him a pm to ask further questions about wiring etc. from what i have read he did most the work himself.
I think for all the trouble it might just be better to get a RB25DE without VVT and just use that. What ECU would I need to use if I were to turbo that setup? R33 RB25DET?
Last question is what is the difference between the RB30E long and short block and do you know what the short block comes off?
if your gona talk about rb30det you need to go through that sticky as that has all the info. use r33 turbo computer with vvt head. rb20det for r32 rb25 head. the only rb25de head that doesnt have VVT is R32.
im pretty sure you have to run an aftermarket ecu to keep the turbo happy
the short block is just an rb30e with out the head on. a long block is with the head on. they still come from r31 skylines or vl commys
So an R33 turbo ecu for a RB30DET with VVT and a R32 turbo ecu for RB30DET without VVT.
I was thinking the stock computers might be able to handle the corresponding stock turbos or maybe something a little bigger? Could it be because of the larger displacement the mixtures will be wrong and need to be corrected with an aftermarket ecu??
for run in you can use stock ecus. but you still cant hit boost.
as i said before. i dont know alot about turbo rb30s cus i was never aiming to build one. rb20det ecu can be chipped so it would handle. aftermarket is best.
cheers eug
yeah it sucks but there isn't anything i can do. it was acttualy knocking after like 5kms so it musta been pissing out the oil. i didnt see it was leaking oil due to the fact it was pissing out the coolant.
it also means i can get the coolant leak between the inlet manifold and the head sorted too.
but argh more waiting!!
i should be able to find out whats happend and what needs fixing on tuesday so i guess thats D-day
all i can say it is well worth it and im pleased with the engine's power and delievery. yeah i cant wait to dyno or get some drag/circut times either. ill be sure to post them up.
now i know what dondenoto gets to feel everytime he drives his r31 ;)
Edited by BADR33
GOOD NEWS, sounds like the bearings will be fine. the oil was leaking outa the top fitting of the external oil feed due to me not doing it up tight enough. but it felt tight to me when i did it cus i think it was catching on the back of the cam cover back plate. stupid engine reconditoiners telling me that if they did it it would cost me more.
so that means the rattle is supposed to be somthing to do with the clutch/flywheel area. so that means the gearbox has to come out :) more $$ down the drain but its another thing that will be my fault most likly.
oh well. moral of the story is: wait till you have all your parts, dont rush, and make sure you torque everything up that needs too be torqued as thats probly the cause of the knocking sound.
should have the car back running perfect on friday all going to plan *fingers crossed*
  • 6 months later...
yes im thinking of doing it to. only prob is i got a VVT head on my car. Anyone got a step by step from start to finsh on how to do it. i mean even how to prep the block for the new head.
That would b a good idea for somone that has done to make.....
people would pay for it.... including me
also what happens when you goto rego and they check the engine numbers Wouldnt they be diffrent??
if you get a new RB30 block you can *ahem* stamp your old engine number onto it :D i've heard of people grinding and sanding back the old one and *ahem* printing the new one one.
getting the vvt to work is pretty much the same as having it done with the RB30DET hybrid (check the turbo section for this) basically all the fundamental principals in building the RB30DE can be obtained from the sticky in that thread... (its a looong read over 100 pages - so be prepared to do your homework)
  • 1 month later...
hey sorry guys been a while since iv been on the net.
the rb30s going great.. well except for the suspected cracked headgasket.. but thats not a biggy cus its only leaking oil down the side of the block.
in NZ there is atleast one place that modifys the vvt head to fit it. R.I.P.S is who i got mine through. hes well knowen for building high power stock internald rb30det cars.
i havnt been pulled up at all for my engine as it still looks like a stock engine. just a little taller. but i think NZ is a little easyer on cars.
im just looking in to some reground cams now as i only want to take the head off once if i can help it. so might also look at some minor porting and polishing at the same time if i can afford it. then probly an ECU and a few other things. im also looking for some parts to custom make a hex throttle setup.
  • 4 weeks later...
yay i finialy got the chance to go down the 1/4 mile..
started off with 16.3s. then i got down to 15.5 at 93mph on a unpreped track..
because of the lack of traction i was only doing 2.6sec 60foots
didnt help with running a single spinner at 2.5degrees camber in the rear. oh and running with the 18s on...
all i can say is bring on the 2way diff and reground cams!!
your mph indicates a much faster time.. something like low 15s or possibly even a high 14.
i reckon an LSD from another R33, and improved launches, maybe some 16" rims and tyres and you'll be running heaps better
Congrats on the time geoff, you should be able to get those times down with some better tyres and the correct setup etc, i was there on sat and saw ur car parked next to crux, i was in the green ford BA xr8, it was a completly shit day and a waste of a trip.
Yours cars lookng great man!
    • No, so what happened is. I put a bunch of filler then I sanded it all down, I removed all the filler (unintentionally), then I put the epoxy primer on because that section of the panel is bare metal. The car is parked outside so I needed to protect it in the meantime incase it rains.
    • It’s definitely an import, the Aussie ones have reflectors in the rear bar, it’s also a turbo which none of the Aussie one were.    I remember back in the day I want a twin turbo z32 so bad and then I saw a 32 gtr and that was the end of that lol
    • Same can be said for Subarus motors ha ha!   I like the 300ZX, I nearly bought a Z32 before I bought my first Skyline. It was going to be a project. Then I found out there was a bit of a dodgy title with it... As in, someone attempted to commit insurance fraud with it and there was now some dodgy legalities around it. So at 18 I walked away from it.
    • The below is what the readings I had with the fuel pressure gauge which were correct. It seems like the issue is mainly during drive and not idle. I bought the new hanger hoping it could be the issue, perhaps I ruined something while cleaning, but I have not installed it yet since I have to wire up everything with the new plugs.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
