Hey guys, attached are some pics of my new POD setup (GF got me the filter for xmas, now that's a women =D )
Just curious to hear/see what others are doing as the car feels a bit more sluggish during the day but better when it's cold, due to heat soak I imagine during the day. I got given some heat shield foam for free when I bought that heat shield so wrapped the intake cooler pipe as well, not idea if that will make any difference or not.
Please forgive my K & N sticker rice, I wanted to put it on somewhere =D Half tried to hide it.
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/
Heh, I thought I might get a few questioms about that. I bought it from a seller on these forums who I think got it from the yahoo auctions. All the instructions are in Jap. It looks great but I'm a bit dubious as to how well it actually shields ^-^
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1835192
Is is actually carbon fibre or is it steel mesh, coz if its steel mest it wont shield at all however i do believe that carbon fibre is ok, correct me if i'm wrong anyone.
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1837053
The material itself appears to be fibreglass with a CF layer on the visible portions.
My shield aside, I was hoping to get some pics and thoughts on how others are doing there setups as I was wanting to run another cold air duct from somewhere =)
Edited by ActionDan
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1837089
LoL :lol: Guys the point of this thread was to get some pics/ideas from others about how they are feeding cold air and protecting from heat. In regards to my shield, I'd hope you could clearly see from the pics that the flat portion of the shield is FAR too wide and would protrude outside the engine bay area if it was on the way you are suggesting. For reference, I did try this, as I originally thought I'd put it on backwards myself, it does not fit the other way round and the air snorkel does not come close to the pre-made hole for it. I've also got a pic from the instructions below that shows how the finished product should look.
Cheers :)
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1838434
Yeah and even though I have this setup, I'd still agree with you. The shield was cheap and I love the way it looks so yeah, had to go for it. I'm keen to get some more cold air flow in that area though, how is everyone else getting there cold air in?
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1838467
From the diagram, it looks like the main purpose is to shield the air coming from the snorkel from hot air in the engine bay.
I remember that someone once said the ideal conditions for a pod filter is to take in air from all directions which you impede by enclosing a pod. This design seems to follow those principles...
..or maybe I'm just talkin nonsense! :)
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1838759
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
