I own an R33 GTS-t with just an exhaust system and pod filter, and noticed that in the heat we've been having lately the car can feel a little laggy. I'm only running stock boost but i'm hesitant to rev the car much beyond 4000RPM on the really hot days, just seems cruel.
I've been considering a Hybrid Intercooler kit, but not having too much tenchnical knowledge i don't know what to look for. I found this one on eBay and i'm wondering if it would do the job?
Hybrid Intercooler
I plan to run a little more boost futher down the track but not straight away. I'm mainly more concerned about the welfare of my engine and components.
Also, for those people who have installed intercoolers, is there something i can say to the insurance company that doesn't scream 'performance upgrade' when i tell them what i want to do? Cause i figure if they feel it'll increase performance it will also increase my premium. I realise that without raising the amount of boost it won't make a huge impact on the performance, if at all.
Thanks in advance!
I am also curious to know what type of cooler or if there are any straight bolt on kits available for my r32 GTST...
with the insurance you can tell them its only for the safty of you turbo because we have hotter weather then Japan we ned to cool the turbo more efficently ( dont quote me on that i just thought of it then)
That's not really what intercoolers do. They cool the charge air into the engine... your stock one should be fine, even in the heat.
If you're worried about your engine on hot days get an oil cooler. A stock skyline won't have problems on hot days it's just not running as well as it would be in cooler weather because cars won't boost as much on hot days.
I won't take my car out on 30-40degree days at all.
Hybrid Intercooler
Thanks in advance!
If you don't already have it, start with a heat shield and a cold air feed for the POD. Unshielded PODs are a big power killer, especialy on hot days.
:O cheers :)
We found another black s2 manual coupe with stockies, eh Dezz? ;o)
Same thing here, I don't go over 3-4K on a really hot day. With the A/C on and the clutch-fan locked on, the car is very sluggish... but the clutch fan is doing its job of cooling the radiator, so I drive softly and count the hours down till the sun sets.
With insurance, its a big ad saying 'I have a big shiny intercooler, therefore my car is turboed' I think thats more so what they are worried about, and the fact that you want the cooler for a reason, and it might be for the safty of your car, but if your not on boost, you dont need it, and your not going fast. The cooler is telling them otherwise. Insurance companys arent stupid, just the people on the phones can be.
And I dont mean to come across as rude, but they are cars... not babys. They can take a bit of punishment.
p1r48r, if you have concerns about the big shinny intercooler thing at all you could go for a ARC SMIC considering you are going to keep the boost low :P Awesome stealth mod !
StOjA, one of the best kit's for a 32 GTST ( IMO ) is the TRUST V-SPL since it bolt's up perfectly, there's no need to cut any 6" holes in your body work, the return pipe from the cooler to the engine runs mostly in the cool air flow and not in the engine bay, right in the path of hot air from the radiator and there's minimal cutting of the bumper / reo required. It does depend on you $ situation though :P
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
