yeah you can get them repaired, but the repair will cost more than a $89 sub.. or at least veryt close too it if your lucky... i owuldnt bother personally.. and some of those pioneer subs go quite hard... depends what your expecting really... have a listen to them beofre you buy and see if they meet your requirements... but one thing to keep in mind... if your burning out voice coils you may want to look at why before you sink any big money into another sub (i.e not enough power from amp or running excessive power etc etc..)...
cheers,
damo
You can never have too much power :lol: just turn it down before it distorts, as an aside, if you have a dual coil sub, run them at 4 ohm - running at 2 & 1 ohm is for competitions, it heats up your amp and cabling and effectivly gives you the same sort of power with reduced lifespan from your equipment :huh:
  • 3 weeks later...
unless your emotionally attached to that sub for some reason, just go get a new one, ne that can handle the power of your amp... you will thank yourself for it... (buy in RMS, and buy a little under what the amp is rated at, but no more then say 50 watts...)
ive rooted voice coils before, i think ive rooted subs in every way. I once ran a sub so hard that the wires that took the power to the coil actually snapped! due to excessive movement. i thought it was pretty impressive, and a bloody easy fix too...
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
