Id be heading probably eastern freeway, accross the top of the city, calder freeway, calder park
We could meet at a maccas or something sure.
Semi RWD..whats that? ATESSA like moi?
Sure, will come up with something on friday arvo or you can tell me a place where you want to meet up too.
  • Replies 113
Further info is anyone is not quite sure -
REQUIREMENTS:
All you need is a registered vehicle, helmet, license and a need for speed!
TIMES:
Gates Open - 4.00 PM
Racing Starts- 6.00 PM
Racing Stops - 11.00 PM
COST:
Competitor Entry - $55.00 (Incl. GST)
Burnout Comp - $25.00 (Incl. GST)
Spectator Entry - $20.00 (Incl. GST)
Children13 yrs. & under- FREE
NOTES:
No alcohol permitted through the gates.
No pets or animals permitted through the gates.
Food and refreshments available
I will be at nunawading maccas at 3:45 ok. Look for the guy in the wagon :)
Ill have to pick up a mate from resivoir on the way, but if there are only like 2-3 of us maybe you guys will come with, else, we'll split up on bell street.
See you there tomorrow everyone.
Dont worry about semi slicks at calder guys, I rekon there not necessary. I ran a 12.5 with a 1.8 second 60 ft on bald Dunlop SP8000e - granted they were 265s, but still its all comes down to the way you launch, you gotta remember the start line is grippy as f**k, big burnnout on st tyres gets em even grippier. Its not like the street at all, ive got mates who dont wanna take there cars down because they compare launchin it at the track to like launching off the lights - its not the case - trick is to keep the revs high so it gets onto boost fast, and as the lights stage on the yellow, keep ur clutch at the friction point jusssssssssssssst before it grabs, dont shit urself from a little wheelspin but if its excessive just knife the clutch slightly. Another method is handbrake, but i dont like it because it can upset traction. Done be shy thru the gears, no flatchanging, but sharp quick and precise, keep the shifts stictly to the redline, i see so many ppl shifting early. Also keeping the car cool right up to the line helps, when ur in pits getting ready for a run, engine off, bonnet up, get a couple of mate to push the car. It looks stupid but I helps so much.
Just some advice for those who havent raced, I really enjoy my drag racing, ive probably had close to 50 or more runs in all my cars thru the years.
Best advice though, dont distract yourself, just get out there and have fun.
I was going to put on the semis, but couldn't be arsed.
I'm running 255 Hankook Ventus Sport which hook up okay.
Previously I have run a 1.9 60ft so I hope I can repeat that.
I'm buying a hand water spray so I can cool the pipes after each run, and also cool the oil cooler and as well. Gonna look like a goon, but who cares. Temperature = bad!
Water spray is a great idea to take down there, make sure everythings cool. As for sprayin on the oil cooler - what for lol, ur pushing it hard for less than 14 seconds. I dont think there gonna be soaring.
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
