A few people have been wanting this, and I found a place that sells it.
Coventry Autoparts in Geebung. Turn at the Maccas at Virginia if going along Sandgate Rd. Or follow the road past the Geebung Rail station if coming from the other direction (Gympie Rd)
Cost me $80 for two 1 litre bottles.
https://www.sau.com.au/forums/topic/10122-redline-shockproof-gear-oil/
damn ive had this stuff sitting in my car for 5 days now and haven't got around to getting someone to change it for me.
I did the engine oil without a problem but i think changing the gearbox oil is too much for me with no equipment/knowledge.
I got it from CRD
http://www.motorsportworld.com.au/outlets/croydon/
$100 for 4L (requires 3.5L and its actually a 3.7L bottle).
$10 next day courier delivery. Pretty sure they were at/near Silverwater from memory.
Yes I had the lightweight put in my car yesterday (Tuesday). I could notice a difference immediately on the drive home (3km) and it was better again today on the drive to work (3km).
I think by this time next week it should be at its full effect (400km later).
Deffinetly worth the $110. ($25/L + $10 Postage)
Edit: The easiest way I can describe the difference is...
standard oil:
When cold its very hard with 1st <-> 2nd + 4th sometimes crunches.
When its warm (1hr of driving) things aren't too bad but 4th still crunches now and then.
Redline oil:
Cold = the same as warm with the standard oil
I'll give it afew 100 km's first before i make a final judgement.
Verrrrry impressed with the oil so far.
Originally posted by 2fardown
A few mechanics I have spoken to have warned me against using such a slippery lube, as it doesn't let the synchros engage or something like that.
Though if you synchros are already pretty shagged then I spose you can't really do more harm.
hmmm....If sounds are anything to go by then my synchros are much healthier after the redline oil. I am sure crunching into gears is not as good, me thinks.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
