Gents,
can any one help me in regards to what degrees in and out i should set these cams up at.
I currently have fresh motor , 26/30 and have set them up at 0 degrees.
Any of you chaps had experience with this set up and what did you find gave results.
I haven't given all my mods but if any one would like to discuss and give a little advice then it would be appreciated.
Should i leave as is until run in period is over, then adjust cams when final tune and boost is determined?
I am not sure.
thanx
Edited by exXU1
https://www.sau.com.au/forums/topic/101319-hks-280-pro-l-cams/
My suggestion would be to adjust the cam timing on the dyno, every engine is different. The higher performance spec, the greater the potential for difference.
:rofl: cheers :rofl:
Edited by Sydneykid
