R32 or R33?
97 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 100
im going by majority of the arguements we all seem to have? make ur own poll cos this one is my poll i shall put wat i want on there.. =P thanks.. and smfn mean something, please my apologies for my wierd chatting short cuts ><
id say the reason for not having 34's in this poll is because most people would choose them over any other line, and the reason why the 35 is not in this poll is because most people would have it at the bottom, close to where the 33 is at. and 31's well, i really dont know, maybe because this isnt www.r31skylineclub.com :)
Anywho, we all know the 32 is the fastest, the hotest, the sleekest, the sexiest, the meanest, the most beautiful line there is. its a true/known fact, ask any 32 owner :unsure:
This pole just shows that 33's are NOT the most common Skyline..........
Since we see more 33's on the road, why are the 32 owners so embarassed about driving their cars? :unsure: Maybe because of all the rust, lack of power/torque, dated shape, etc....:lol:
/stirs the pot :), then runs.....................
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
