R32 or R33?
97 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
And I quote:
32 GT-R:206Kw/353Nm
33 GT-R:206Kw/629Nm
34 GT-R:206Kw/392Nm
Plenty of torque in them R33's Jayce, almost double those other weaker cousins...............lol
ah,yes...my bad! Shoulda read R33 GT-R 368Nm...
Ya got me fair + square!
  • Replies 100
And this 32 vs 33 thing, we are really talking about the classic Elle McPherson vs Sophie Hawkins aren't we??
I mean Elle was damn good, still is OK, but she can't stay that way forever.......so along comes Sophie to continue the good work.
I can see parallels here.
sophie? dont u mean jennifer?
When you do get the chance to drive a GTR (properly) Leigh, you will realise why they are so much more appreciated than the GTST, I have driven a very serious R32 GTR before and since then I have lusted after one ever since (particularly an R32 GTR Vspec2... Hmmmm I wonder who has one of those?) but I simply cannot afford one, let alone the insurance price tag, but ONE DAY! I will have one!
Jayce..... If you happen to die of "natural" causes can I have your car pretty please? You know Ill take good care of it! :P
ive driven an r33 gtr vspec n got quite bored of it. only thing worthy of noting was launching. didnt get 2 try out cornering it on the edge but it was enough for me.
Ya missed out,Kam'! One of life's genuinely religious experiences...
Oh,by the way-the Owl thing-WTF?? There's gotta be a funny story behind THAT,surely?!?
so which one of you guys has created several accounts just so then can vote, cause there is not enough of us commented to match votes, unless ppl out other sections have voted, but not commented. <------ Highly unlikly
ADMINS.........
Edited by race_snooze
R32 [ 42 ] [56.00%]
R33 [ 33 ] [44.00%]
After I voted.
This is a silly conversation, the r33 was created in error much like the 2001 WRX... both pretty but wrong. The original WRX was a cult car like the CRX before it, even now it is appreciated more than its younger brother the 2001. Its much the same for the 32s and 33s, I had a guy just the other day come ask me if mine was a r34, ok he was out of the game but new a 34 was a newish car, surely no one would mistake a so called "aged" car for a new one, put simply they have aged very gracfully, as for looking better with a kit, yes the r33s look better with a kit much like a prossy with heaps of make up. You still dont want to wake next to it!
Looking at stat's, Jayce has clearly shown that the r32 GTR was the quickest and most known of the Skyline race, but lets also look at how many r33s you your self know that have been crashed. I can count close to 9 and I only know 1-2 r32s, Driver you may say, but these are a japanese family car = more crahing- bad design I say...
I would say my preference would be
- R34 GTR
- R32 GTR
- R33 GTR
- R32 Gtst
- R34 Gtst
- 2001 WRX
- R33 Gtst
hehehe
* the opionions in this post are mine and mine alone, no offence was intended to anyone (excpet R33 Gtst drivers, who claim on R32 GTR popularity).
your welcome... :)
All quiet on this topic...Looks like the 32 takes the prize,yes?!?
just because there are alot more poor people out there who cant afford 33's they figure they had better vote 32's as they may have a chance of being able to afford one :D
*starts up a fire and runs and hides*
Disclaimer: This opinion above is that of a guy i spoke to on the street some time ago it does not reflect my personal opinion so as such i can't be held to the above quote :lol:
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
