R32 or R33?
97 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
And I quote:
32 GT-R:206Kw/353Nm
33 GT-R:206Kw/629Nm
34 GT-R:206Kw/392Nm
Plenty of torque in them R33's Jayce, almost double those other weaker cousins...............lol
ah,yes...my bad! Shoulda read R33 GT-R 368Nm...
Ya got me fair + square!
  • Replies 100
And this 32 vs 33 thing, we are really talking about the classic Elle McPherson vs Sophie Hawkins aren't we??
I mean Elle was damn good, still is OK, but she can't stay that way forever.......so along comes Sophie to continue the good work.
I can see parallels here.
sophie? dont u mean jennifer?
When you do get the chance to drive a GTR (properly) Leigh, you will realise why they are so much more appreciated than the GTST, I have driven a very serious R32 GTR before and since then I have lusted after one ever since (particularly an R32 GTR Vspec2... Hmmmm I wonder who has one of those?) but I simply cannot afford one, let alone the insurance price tag, but ONE DAY! I will have one!
Jayce..... If you happen to die of "natural" causes can I have your car pretty please? You know Ill take good care of it! :P
ive driven an r33 gtr vspec n got quite bored of it. only thing worthy of noting was launching. didnt get 2 try out cornering it on the edge but it was enough for me.
Ya missed out,Kam'! One of life's genuinely religious experiences...
Oh,by the way-the Owl thing-WTF?? There's gotta be a funny story behind THAT,surely?!?
so which one of you guys has created several accounts just so then can vote, cause there is not enough of us commented to match votes, unless ppl out other sections have voted, but not commented. <------ Highly unlikly
ADMINS.........
Edited by race_snooze
R32 [ 42 ] [56.00%]
R33 [ 33 ] [44.00%]
After I voted.
This is a silly conversation, the r33 was created in error much like the 2001 WRX... both pretty but wrong. The original WRX was a cult car like the CRX before it, even now it is appreciated more than its younger brother the 2001. Its much the same for the 32s and 33s, I had a guy just the other day come ask me if mine was a r34, ok he was out of the game but new a 34 was a newish car, surely no one would mistake a so called "aged" car for a new one, put simply they have aged very gracfully, as for looking better with a kit, yes the r33s look better with a kit much like a prossy with heaps of make up. You still dont want to wake next to it!
Looking at stat's, Jayce has clearly shown that the r32 GTR was the quickest and most known of the Skyline race, but lets also look at how many r33s you your self know that have been crashed. I can count close to 9 and I only know 1-2 r32s, Driver you may say, but these are a japanese family car = more crahing- bad design I say...
I would say my preference would be
- R34 GTR
- R32 GTR
- R33 GTR
- R32 Gtst
- R34 Gtst
- 2001 WRX
- R33 Gtst
hehehe
* the opionions in this post are mine and mine alone, no offence was intended to anyone (excpet R33 Gtst drivers, who claim on R32 GTR popularity).
your welcome... :)
All quiet on this topic...Looks like the 32 takes the prize,yes?!?
just because there are alot more poor people out there who cant afford 33's they figure they had better vote 32's as they may have a chance of being able to afford one :D
*starts up a fire and runs and hides*
Disclaimer: This opinion above is that of a guy i spoke to on the street some time ago it does not reflect my personal opinion so as such i can't be held to the above quote :lol:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
