  • Replies 42
Gee they all this makes them sound like a real good turbo!!! lol
Laggy, weird design, china born.......im beginning to think they might be worth the little money you pay for them!!
THERE IS NO DUMP FOR THE Wastegate flap like Garret and EVERY OTHHER BLOODY TURBO.
http://www.turbobygarrett.com/turbobygarre...71_452203_1.htm
you mean like this one? It's also a fairly common arangement on hitachi, mitsubishi, and as a result trust internal gate turbos from the mid 80's to the mid 90's aswell. The v band arrangement isn't uncommon either.
You're talking about a turbo that is obviously old tech (at least the core) but it makes it's claimed power apparently and it costs bugger all. It doesn't mean i want to go out and buy one as i think you would be better off getting something a little easier to install (read common t3 exhaust arangement) and so save some money there that can then be spent on the turbo itself.
What i do like about these turbo's is they are obviously aimed at the performance enthusiast on a budget, the same as the china intercoolers and the china manifolds and the china radiators and the china coilovers, they offer 3 versions to suit your application, they have warranty, and they offer install if you can't do it yourself (which means warranty support).
well
similar exhaust outlet for the wastegate flaap.
end of story these turbos are for ricers who just want a "turbo car"
NOT A TUNED PERFORMANCE CAR! ( as the japs say)
POS TURBO!
so are you gonna keep bagging something without fact?
no one post has any.
That design wouldnt be so bad as its cleanly split, not like other int gate turbos that are close to the turbine outlet
nismoid.. i have facts
in my own brain from experience
ive tuned 5 cars with these turbos.. customers like them.. nice big top end power after 5000rpm till redline *usualy 8,000rpm* but they suck for street racing!
period!
drag only or watever
Edited by s13rb26
here is a lag diagram
on a ca18det
kkr 330(smaller one)
full boost between 3000-3500 not bad for a ca18 if you ask me.. good midrange as well
other mods it has is a z32 airflow meter and gtr injectors
Edited by fatz
Yeh i agree thats not too bad acutally. Seen as i would be looking at using it on an RB20 i would be looking at the smaller version, i.e. not the 480, i think its the 440?
And guys theres no need to argue, were all friends right?
......right :)
period!
are these the 480 on 2Ltr or 2.5Ltr motors?
If it gives me 250rwkw and full boost by 4000rpm I don't care where it was made...
my mat ehad one on his S14.. and yes IT IS LAGGY.... started boosting at 5000rpm..
Personally i liek RESPONSE@!!!
1.1 ex housing on an SR is going to be laggy, no matter what brand turbo. On an RB25 it may respond differently..
Getting back onto the original topic - does anyone have a dyno printout or experience with one of these turbos on an RB25?
thats the baby kkr330
totaly shit turbo once again........
will pop in no time
will pop in no time
been on for about a month
anyone who puts the 1.1 on small capacity engine is asking for lag
im frends with the distributor so i can get a 10% discount fo a limited time
i think he has sold over 40 units in 4 months and hasnt had one return under warrenty
pete
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
