No shit its not a case of bolting it on and driving away. You really do write some stupid shit man. I read your posts all the time and am constantly shaking my head.
I know many people with GCG turbos as well, and none of them have had problems either, however, i did have a problem
Your the one posting pretty stupid shit... either that or your making yourself look stupid. Take you pick, near enough to the same
Im not being sarcastic at all, i wasnt ever referring to your post. Just because i post after ... wow.. lemme get excited
you couldnt get it to work... thats your own problem in conjunction with your tuner. SK has posted how he gets it too work, like others before him (who dont post on here)
Just because you went through 3 turbos doesnt mean it was GCG'd fault at all.
You can get the wheel specs, you can draw your own conclusions.
You using stock BOV's Paul? :D
GCG S2 high flow (discontinued) and standard computer don't work together, upgrade the ECU.
Some tuning tips;
1. During the boost build rpm, tune it with as much ignition advance as it will take, use extra fuel (richness) to control the detonation.  This ensures that whatever airflow the turbo is producing is ingested by the engine (throttle body size is irrelevant at partial throttle openings).
2. Retard the exhaust camshaft timing, usually around 4 degrees
3. Some mild tuning of the VVT change over point sometimes helps
4. In the surge rpm zone, check the pressure drop from the turbo to the plenum.  It should be almost zero, more than 1 psi is not acceptable.  Look closely at the pipework and the intercooler.
5. In the surge rpm zone, compare the inlet plenum pressure and the exhaust pressure (the lambda sensor point is a good reference).  There should be almost zero difference, more than 1 psi is not acceptable.  Look closely at the dump, cat and exhaust.
The above (with carefull tuning) will eliminate almost all of the compressor surge, maybe even all of it.  Whatever remains you will have to manage via judicious use of the throttle.
Hope that helps
:D cheers :O
PS, this is a unique problem to the GCG S2 (500 bhp) high flow, the S1 (450 bhp) has not had one sinlge problem on the 6 or so cars we have fitted them to.
So if i got manual conversion + powerfc and hand the tuner these tuning tips they should be able to solve the compressor surge
omg, you're running a stock ECU? what a freaken waste... Go and buy an Apexi PowerFC and hand controller for $950, get it tuned and you will be fine.
So many people make the mistake... Get the ECU, fuel pump., exhaust..fmic BEFORE you upgrade the turbo!
The turbo should be the last thing that you increase in size.
perhaps u didnt read my first post......R33 gtst s1 auto(so i cant use a powerfc) running 11 psi
fmic, safc, gcg s2 highflow, full zorst, stock bov i also have a walbro fuel pump and nismo reg.
SydKid cheers for tips... much appreciated.. I just need more time and money to work on diagnosis! LOL. It has got to be something dodge with my turbs/wastegate i recokon as it seems to fix itself at higher revs and under full throttle. (well at least i dont notice it).
I have a seconds dog box on zorst (is rather a queiet zorsts) and no cat.. however is 3 inch the whole way... Could this second dog box be restricting the exhaust flow somehow?
Could my airflow sensor maxing out cause this problem?
First thing in morn once car is warmed up i dont notice it -- could this be some sort of heat related problem ie cooling oil and water lines not working correctly?
????? THere is so much that it could be!!!!!!!!!!
Cheers chris..
I was loosing power due to the disturbed airflow that was being caused by the hole in the mesh that also why i got the compressor surge. I cant say it will work for you just talk to your local tuner and see what they say.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
