Item: 310km/h tomei speedo Cluster for R32 GTR
Item Condition: in good condition
Reason for Selling: dont need it anymore
Price and Payment Conditions: $550ono
Extra Info: this might work on a GTS-T if u get it tuned for it.
Contact Details: PM me or e-mail, [email protected]
https://www.sau.com.au/forums/topic/102018-r32-gtr-310kmh-tomei-speedo-cluster/
Interested if you are sure it will go into a 32 gtst and will do for $400
it will hook up to a GTS-T with no problem, i had it in mine but u will need to tune ur car for it coz its for a GTR.
still for sale, and will take offer's around the $450 mark
mait32"
just wondering mate if you have a gtst how many rwkw? out of rb20/25??"
i got a gts-t but with rb25/30 with 289rwkw
cheers
bill
mait32"
cheers
bill
I have an r32gtst with rb25 in it forgies all the goodies hks3037proS need new cooler and exaust for better flow at the moment only making 250rwkw few months around the 300mark. Glad to have found some one with similar tastes. Im Nathan.
Wondering where you got your engine built unless you did it youself???
And what turbo set up you running.
But the most important thing is which cooler are you using having trouble to find one to fit and flow at least 300rwkw?? PLEASE ANY HELP VERY MUCH APPRECIATED.
hi Nathan, PM me and ill tell u my engine setup. i dont want to Discuss it in the for sale Section
cheers
bill
$370 and its gone.
sorry i cant i already have taken $100 off the price. $450 cheap for a tomei speedo's
still 4 sale
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
