  • Replies 134
Posted Images
Spoke to Bosch Australia today.
'Apparently' they have ZERO stock, Bosch Germany where the Z32's are manufactured have had a problem of some kind halting production.
I can get a very limited number of AFM's BUT no where near the 31 that we need at the moment. I have been told to call back every 2 days as it shouldn't be too long at all.
I'll make a few more calls tomorrow and see if I can scab some from various places around aus to make up the numbers.
Obviously I won't send out deposit details yet..
Sorry ppls, if your keen you may have to wait a little longer. :S
Its been a slow day today, many many phone calls. :S
I was unable to find a wharehouse that had any z32 airflow meters.
I'm expecting a call from Bosch tomorrow, I will know where I stand with regards to a time frame then.
Please bear with me as the group buy will definitely be going through.
WHEN is in the hands of Bosch Germany.
Aparently they are a bit scarce at the moment... I bought one less than a month ago from Petroject in Vic.. they said a number came in to the country from Germany, and they were only allocated 2 units of 10 that they requested. I got the last one they had in stock :P
They are indeed scarce.. :(
Bosch Australia have 20 items coming in. They won't be able to supply us with the required number of airflow meters until May. :D
Sorry for the hassle peoples. Early January the airflow meters were available, a production issue occured resulting in no AFM's. :P
I will PM every one as we approach the time and see if your still interested in an AFM and create a new group buy.
For those in desperate need for a Z32 (VG30DETT) airflow meter APC appears to have them listed at $360 which is a pretty good price.
http://www.apc-racing.com/browse.asp?cat=14&car=11
is this group buy still going on?
z32 fits r32 gtst right?
They will fit the 32 gts-t with the tomei plug or a plug from a vl but it will not work without a piggy back ecu or aftermarket of some sort.
Greg
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
