I was reading my instructions manual for the stealth fx bov I bought and it has this written on the bottom.
"GFB products are engineered for best performance, however incorrect use or modification of factory systems may cause damage to or reduce the longevity of the engine/drivetrain components. "
Does this mean that a bov if running correctly without the typical symptoms stalling etc can be harmful to my or your cars engine?? just something that popped into my mind. All these people with bov's when it may be bad for the engine.
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/
the bov or commonly known as recirculation valve was fitted to later model turbocharger cars (earlier models didnt have them, aka vl turbo style) to prevent excessive turbocharger failure and premature wear caused by compressor surge on gearchange.
normally without a blow off valve or recirc value when you back off on the throttle or during gear change the throttle body closes and the pressure has to go somewhere that is built up. it goes back towards to the turbocharger as it has no where else to go and basically gets chopped by the spinning compressor wheel and the blades recieve a fair impact "shunt" by the exessive pressure collision. this can lead to premature turbocharger failre in the bearings and compressor wheel.
another side issue is excessive stalling by an atmosphereic blow off valve, the bov functions as a half recircluation valve, it prevents turbocharger failure by prevent the surge but dumps the pressure to the atmosphere. the engine management system (particulary airflow meter) does not know that the bov is venting to the atmosphere and there expects a certain amount of air present in the system (as its told by airflow meter). however the atmo bov dumps the pressure (and air) and the engine uses the amount of air that has been recorded to work out ign timing and fuel however the amount of air in the system is much much less that what was recorded so it goes into a stall
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/#findComment-1871172
so in summary cars with no bov or one that is too tight, aka those with really loud turbo flutter or vl turbo woop woop wooop sound is causing damage to their turbo one way or another, and besides it sucks for quick turbocharger response as the compressor shaft gets slowed down by the backpressure collison
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/#findComment-1871178
I sent an email to brett turner the engineer from GFB and in regard to the stalling he wrote back
"I have come across this problem before, it only seems to affect a handful of
R33's. The problem lies with a super-sensitive airflow meter, What I did determine is that the stalling is related more to the
spring pre-load than the atmosphere venting. I
would suggest softening the spring 2-3 turns by winding the chrome cap
anti-clockwise.
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/#findComment-1871307
Yeh thats all he wrote to me. Which was pretty interesting as you say because mostly we hear its the atmo venting but this can be different. I was also interested to know if a bov which seems to be running good if its doing silent damage. He didnt respond to that question hence why i thought i would bring this topic up.
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/#findComment-1874089
i had a blitz BOV on my 32 a while ago and i also kept the standard plumb back. Never had a problem with stalling. i think you could get away with running 50/50. try and see how you go - your not gonna hurt the turbo as youre venting the pressure thats built up. The only downside would be - your car may run a little rich and you may get some stalling issues. just adjust the BOV to a setting that seems good for the car and sounds good to you.
https://www.sau.com.au/forums/topic/102062-are-bovs-safe/#findComment-1885838
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
