So there is a lot of info on getting gtr's to run in rwd mode, and I was under the impression that stagea's were the same as 33/34 gtr's not able to easily put it into rwd mode other than removing drive shafts.
True/False?
https://www.sau.com.au/forums/topic/102172-running-your-stagea-in-rwd-mode/
From PM :)
its a peice of cake, remove a fuse in the engine bay, drive the car for like 200m just to bleed the pressure out of the front, then away you go. we have 2 customers with 4wd stags that come here. They pull the fuse out at there place then drive it in, by the time they get here, all good to go. give me a call if you are chasing some more info...
cheers
b.
milanco pro dyno
(07) 3390 8133
Yeah I read this thread but didnt think it worked for Stageas..?
Also people seem to think it is easier to remove the shafts....?
http://www.skylinesaustralia.com/forums/in...showtopic=52486
Tried that with both the RS4 and the 260RS, you will to remove the driveshaft. The fuse pull works perfectly on the R32 GTR and GTS4.
Edited by RBNT
Drop the shaft if the only way
I hate the 4wd sometimes, is it easy to drop the shaft?
Trust me man, you dont have to drop the shaft. If the stagea seen at willowbank was white with odd looking chrome wheels, body kit and milanco stickers on the rear windows, then that is the car that we tune on our TWO WHEEL DRIVE DYNO. Geoff (the owner) was out at the track on wednesday night..... awd stageas can be tuned and run on a 2wd dyno.
I understand you CAN do it, but what about if you SHOULD do it like that?
How does driving the car bleed off the residual pressure on the clutch packs?
I have been told that yes you can do this fuse method in Stageas, R33s and R34s but you shouldnt as the way the system is set up (Unsure of those details it was a while ago) screws up the clutch packs unless the front drive shaft is removed..somthing about the shaft still roatating and wearing some other part down (Damn my feeble memory)
^^^ what he said. The R32, A31 Cefiro and C33 Laurel are the only ones with an AWD system that totally disengages when the fuse is disconnected/switched off etc. R33's, Stageas, C34 Laurels, Y34 Gloria's, Cedric's and Cima's and R34 all have a newer transfer system which dosen't totally disengage. You CAN go for short runs in quasi RWD mode with the fuse out, but a couple of guys found the hard way what doing a full track day in "RWD mode" does to the R33 GTR gearbox.
I couldnt get either of my Stageas to run real rwd. I tried driving for a while and it just wouldnt disengage. Wasnt doing anything wrong, just wouldnt go rwd for me.
I guess a more pertanent question is Why would you want to, esp in a Stagea, unless you wanted to go to a skidpan day, but even then, I would much prefeer trying to 4wd drift ON A SKIDPAN than rwd........?
I mean it is designed to drive all four, so other than being able to tune it on a 2wd dyno, I dont see much point in it....?
Yeah see I am over the whole drift thing, I drifted the crap out of my old r33 at Queensland raceway and since I have resigned not to flog the crap out of my stagea, I dont think I'll be drifting it on a track anytime soon.
But I am very interested to get it onto a skidpan so that I can have a go at 4wd drifting. Last time I went with my r33, the instructer had a pretty worked STi and he took me for a ride and it was sooooooo wierd going past the 90 degree angle and pointing backwards and then have it just straighten back up, was quite different then rwd drifting that is for sure :w00t:
Last time my stagea was on a skidpan, Gary could not get it to drift, it had stock suspension and the auto in it at the time, but no matter how hard he yanked on the park brake, it would go to slide out and then just straighten back up, looked funny, but damn he got some great times on the motorkana section that day!
But there has been just a couple of additional bit put in it since then, so still waiting on my tune and then I'll be looking for a skidpan day to give it a go :P Personally I dont think I'll need or want to put it into rwd to drift it, the wieght and length would make it harder to keep on the drift wouldnt it?
Hi all... in issue 15 of HPI a chap that had one of the first stageas in the country said he made a simple 4WD bypass switch...that works on stagea's, GTR's (didnt say models) and 260RS's...and theres a pic of him doing a burn out to prove it...would seem a lot easier than these other methods.
i pulled the fuse in mine and went for a quick cruise. found that it does disengage the fronts, no worries. (even with the auto it got the rear tyres spinning).
i did find that my rear tyres chirped like crazy taking slow, tight corners though, and turning while reversing is a bitch. it turns out that it locks that back diff. i have no idea why. i know that the atessa drives opposite front and back wheels (front left, back right, or front right and back left, depending on traction, unless you engage the central lock). would it lock the back two so that it still has two wheels to send power through? beats me.
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
