  • Replies 97
Posted Images
Thought I'd post some pics. Thanks to Chrisso 925 for these. (He was the mastermind of the crew's pit shirts! - smart arse!)
The poor pics are of #962 (our Suby from last year), after it sustained major damage on Mt Black on day 5. Also a 33 GTR that rolled on the same stage.
  • 2 months later...
Off thread, but BP Ultimate is now in Tassie Marlin, including the servo in Burnie
TT
Oooh! Good news!
Do you know if it's good quality? Whitey was telling me the fuel comes in on one ship, and they don't really wash the tanks well? So, in effect, you pay for the good stuff, but get a bit of diesel/metho/kero thrown in for free...
Would you agree?
Oooh! Good news!
Would you agree?
Well it is only 98. We run 102 in the circuit car (and in the old RB20), but its got to be better than 95 + booster. My thing is at about 9.5:1 so it could probably run on kero anyhow.
Come Targa 07 we will probable run a 102 or >98 race fuel anyhow... but not with the ADR tractor tune.
Catch ya
TT
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
