Guys,
My engine will be finished shortly and i was wondering the boost i will be able to run on pump fuel, Optimax Extreme
RB30 Bottom End
RB26 Top End
9.0:1 CR
T04Z 1.00
Ported
HKS Cams etc
THanks guys
how long is a piece of string really.
until you get in onto a dyno, and get the tuner doing (hopefully) what he knows best.
Then there is no real way of telling to be honest.
Every car is different in its parts etc etc so its really an impossible question to answer with little more than a guess
https://www.sau.com.au/forums/topic/102317-how-much-boost/#findComment-1877857
20 psi will get you there as I have done this on my GTR with a RB26 (400kw). Others have also acheived this, same turbo, boost, cams. A note on this is that head work is required to lower flow resrictions You can get this running 260 cams or more if you run larger cams. Running 25psi will get you 450-470 mark as R32-GTS got 468kw with 25psi running 272 cams.
This of course will all depend on your tuner, but the engine is capable. Even more so with a RB30 bottom end - very nice :)
https://www.sau.com.au/forums/topic/102317-how-much-boost/#findComment-1878966
272 cams, some nice lift say 10.2 or more, big exhaust system and fuel setup, I'd say 470-480awkw running 26psi and push the T04Z all the way!!! Check on R32-GTS results which was on Ultimate 98. Running Extreme is good for another 10-20kw on top so I don't see a problem. This is very similer to a setup I want :)
BTW running 9.0:1 CR is so very nice, don't forget about good quech.
cheers
Adam
https://www.sau.com.au/forums/topic/102317-how-much-boost/#findComment-1879848
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
