if u can grab the ecu serial number (23710-XXXXX) then i can probably check when ur ecu is from. most likely if u havent wired up the consult port ull need to do that, but thats only a minor issue.
  • Replies 152
not yet...got word back from one of the two places i contacted about getting it custom made (this one in the US) and i should get an estimate on how much it would cost from them soonish.
still finalising some of the hardware - ive decided on just serial consult interface capability (was thinking of usb, but decided the usb if at all would be an adaptor onto the serial - have already tested this in its basics and its fine, but will cost an extra $20 and probably diy to put together). want to have the pcb made so that all future functionality i might put onto the device is there to start with - ie room for eeprom to store data, buzzer for alarms, etc
ive found a decent LCD (viewing angle 50 from up, 60 from below, and 40 each side which is by far best ive seen, good refresh time, also is wide temp which is great) which ive got a couple of to test with. just hope they are kept in stock as i bought 3 of the last 8, but it might take quite a while to get more in
desktop and ppc software is on hold while im working on this. havent really started ppc app aside from just testing some stuff will work on it. good thing will be that knowing how to make it look will be harder than actually doing it
be working a bit on trying to get a beta of the desktop version available today
got a first quote back on the enclosure being custom made, going to be around the 30$ in large quantities (ie 50-100), which i guess if i cant get anything better will go with it. around $15 more than what i budgeted for, but still have another place to check out so will see if i can get something better there
Edited by NewKleer
still unsure if ill be able to do that, will take a while to write up a construction guide and whatnot, and troubleshooting any problems will be hard. construction itself might not be too difficult so i might just do that myself
essentially it comes down to whether i think ill save more time doing it myself or not whether i can offer it as a kit. wont rule out anything yet though
at this stage i think best case scenario would be end of march for when i get things all ready by (either diy or assembled), but have been busy at work lately so havent had much time to finalise stuff like pcb layout (which then effects the enclosure production).
cool take your time.
Attention to detail will pay off for you- its proof to the rest of us that you're going to have a top product at the end of it :P
  • 1 month later...
here's an update, have made a prototype. which removes a lot of the extras, but am just testing the main screen and will soon be able to test the integrated consult interface, just need to wire up the serial plug.
as you can see the size is still quite compact and am on track to make it of similar dimensions to whats shown there.
shot taken on angle as i had no contrast adjust setup on lcd yet (and straight on was just like all black). whats shown there is standalone and only has the consult plug coming off it.
Edited by NewKleer
  • 3 weeks later...
need to have a draft pcb made for the enclosure to be done (so they can make sure everything fits). i hope to have it done by end of month. then maybe 1.5-2 months till enclosure is done, and at the same time id get final pcb and components ready.
unfortunately due to enclosure costing more and having to get the pcb's done elsewhere to the normal place, current estimate is up around the 175 mark, however this shouldnt change much (and no chance of it going beyond 200).
hardest thing is getting the time to get pcb done with work and uni being flatout. i just want time to stop for a week!
heres the prototype pcb that sits behind the lcd. the lcd "plugs" into the very left "rectangle" box on this thing (and thats the only connection to it, so replacing it will be easy). ill be getting this made soon for testing (about 5-10 of them), so fingers crossed i didnt make any mistakes.
there are 3 buttons - the left one will be (whenever i add the functionality) the "command" button, and the next two will be the add/minus or up/down or whatever buttons. you can then see the switch roughly in middle, here you switch it to left to use the display like normal, or to the right to use it as a consult interface. theres also a lot of future expanability in the board (a lot of places i can wire other stuff in) so hopefully ill only ever need this one layout for anything i do
will be ordering parts soon, and if the first prototype boards i get have no issues, then i can get a full batch done and get the enclosures made (roughly 6 weeks from then is when enclosures might be done).
the novelty of blue wears off quickly once u realise how hard it is to see in daylight and on angles.
but any standard sized (182x33.5mm) 40x2 module can go in. just this one im getting will be wide temp and very good viewing angles compared to most.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
