TO THE MORONS WHO CAN'T READ THE DATE ON A FORUM POST, THIS THREAD IS MORE THAN TWO YEARS OLD! I DON'T REMEMBER WHAT THIS CAR LOOKED LIKE LET ALONE HAVE ANY PARTS. SO STOP ASKING FOR RANDOM BITS!!!
Thank you.
Whole car being stripped for parts - quick sale
Wollongong, NSW
All panels except bootlid damaged - mechanically great
Bought car for parts - lots left
Pickup only preferred
RB25DET, 5-speed, all driveline, some interior, 4 x standard S14 rims, dash components, headlights, tailights etc
ONLY contactable via email: [email protected]
Adrian
https://www.sau.com.au/forums/topic/102422-wrecking-series-1-r33-gts25t/
  • Replies 97
Posted Images
Wollongong, NSW
Adrian
Everyone will want the power window regulator
Have replied to just about everyone I think. If I haven't, Im sorry - please send another email. My inbox is bursting with people wanting window controls :D
Adrian
im after the thing that you use to turn on the headlights and indicate with.. im not sure what its called, sorry mate.. do you have it?
also the front left shock absorber.
Edited by SECUR1TY
How much for the 4 x standard S14 rims? Would they fit a S2 R33 GTST? With or without tyres? Condition?
$500 - 2 tyres are in great condition - 2 in less than great condition.
hey,
What do you want for front calipers and what would you sell the box separate for?
Front calipers - $300 - box $1500 but only if it doesn't sell with the motor.
Indicator stalk - $60 - front left shock - dunno, make an offer.
Motor - $2500 - BUT Speak to kossak and by the motor and box for $3000 and you guys work out the dollars.
Adrian
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
