Hi all, just thought I'd ask this question to see what fuel everyone is using locally and if they have had any bad experience with certain brands/outlets?
The reason being is that i think I have a dud tank of fuel in my car, as I reckon I heard a bit of detonation whilst going for a quick blast through the hills on sunday arvo. It wasn't hot (22-24deg inlet temps) but in 3rd gear @5000 rpm I heard something and got of the gas straight away, and haven't given it any since then, as I still have 3/4 of a tank of this stuff in it!
The servo in question is Mobil, Nth East rd, St Agnes, 98 octane premium. I have never had a problem before, but I want to know if anyone else has had any drama with any particular outlets?
Chris
https://www.sau.com.au/forums/topic/10243-fuel-what-is-everyone-using/
BP Ultimate 98 - no problems so far.
Shell Optimax (98RON) whilst in NSW - no prob's.
Mobil premium (96RON) I didn't have a choice - detonation.
My car has always been tuned on/for 98RON.
I've never used any of the others in the Skyline.
Well thats what I have been using (synergy) for about a year now, with no problems apart from the tank full I have now. I might give it a light run on the way home tonight and listen out for anything, other than draining it, maybe a bit of octane booster will help until I fill it up again.
I am curious about everyone else's response's, as I always thought that the BP stuff was lesser quality than the mobil stuff. Maybe shell should pull its finger out and give us SA people optimax!
If you have 3/4 of a tank of flat petrol why not pep it up with an octain booster? At $10-$15 sit better than running the risk of detonation.
PS anyone have access to comercial quantities of Toluene? As I uderstand its the key ingredient to boost the octain level and quite cheep to buy in bulk.
i've tried all diff types of petrol .. normal .. premium .. 98 ron .. i've tried woolworths premium too ... car feels best with normal bp premium for me .. although i don't push my car much ... i think bp stuff is much cleaner too ... something about low levels of some chemical which others have high quantity of ... can't remember exactly what it was ... normal premium gives me the best mileage ... at least 100km from a tank(dont' ask me why .. it just does) .. get the same mileage with 98ron stuff as i do with normal stuff... and its cheaper by a couple of cents so i win both ways ... just my 2 cents ...
Ok, seems everyone has had good results with the BP stuff, I think I will try that next time I have to fill up
4door_sleeper, octane booster does a good job of fouling platinum plugs, so for now its just running stock boost
I've been using Synergy 8000 for about 90% of the time and it's been OK. When I swap to BP Ultimate i just get the feelign it's not bit more detonation prone but nothing concrete.
Here are some specs of the BP website:
You could just siphon the tank? Then put the remaining fuel in the family run about. If you've got one? Then fill the Skyline up with BP98 & give it a good test in the hills :D
If you do siphon, try to avoid getting any in the mouth :spew: Like I did emptying & cleaning my overflow bottle the other day, whilst changing the coolant :D
Nah, no run about, but I could use it in my 3 wheel dirt bike!!
Can't be stuffed with the siphon, maybe I should just take the cap of and park it in victoria sq for a hour (i shouldn't have said that!!)
will try the bp stuff next
I had the same prob lately too...
I have always used Mobil synergy 8000 with good results....
But lately I got a really bad batch, and the car has run like sh1t ever since....
I have even gone through a tank of BP utimate, and Optimax since, and my car is still not the same?!?!?!?!?!
I find that with Ultimate, I get less pinging on idle, but with Optimax I get more power....
So I have reverted back to optimax, and refuse to run synergy 8000 again...
Chris32......mate that Vic square comment just killed me..::alcoholic
I'll ask the guys at Mobil the fuel specs as well and compare to BP 98 but I don't think it will tell us much.
BP & Mobil obviously have to make 98 octane or better, as that is what they claim but they change the make-up of the fuel in any old way they please that I'm sure effects the "effective" octane rating, if there is such a term. Winter & summer fuels are different for example, summer is less volatile to reduce evaporation in tanks and things they do etc etc.
Zahos, maybe replace your in-line fuel filter near the bottom of the plenum chamber and it may run better.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
