  • Replies 717
I'm sure Abo bob will post the results for all catagories,
but Boosted Zed squeezed out 427 rwkw from his VG30DETT,
go the cardigan wearing, tea sippers . :/
Sorry Mona, got there after 1.00, had to work.
You had a little scare, 500+ ?
See you @ WSID
Just had a look at Stan's dyno graph - from the SATANIC. Very surprising to see that UAS backed off the run before it even ended... meant that peak power wasn't even reached??? The dyno graph just went vertically downwards at the end, power curve hadn't even started to dip yet.
Anyone else see this on their graphs or was it just Stan's?
If I recall his A/F ratios were running a little to lean to push it too much farther.. was a good run.. could have held on a little longer, got a video of it here.. I think the main issue with power was his boost dropping off 1psi..
anyways.. good day.. stuck round for a bit.. than left.. stupid whining gearbox.. shits me to tears now sounds like i'm running a dogbox or something..
you the guy with the white shirt and camera? LOL!!! any vids of my car?!?! :/
Did anyone happen to get a vid of my run?? If someone did i would like to get it. 177.1 with a stock computer wasnt bad, and the induction scream nearly gave me a hard on!!
Who had the RB20 GTS-t with STD turbo Stock ECU and heaps of powa....smoky or what??
sorry to dissapoint.. but wasn't me mona.. I was hiding away.. nah had a singlet on.. not sure who else was there with a camera..
top secret anyone..
nice turn out of cars..
Edited by Links
yer morgs made 365rwkws with 19psi. Top secret car was a little disapointing made 440rwkws i think but had a t88-38k and 25psi i think thought it would pull more then that.
And where was duncun with BBQ :/
:sorcerer: Brad
Yeah great day in my opinion... nice area, plenty of parking (even if it was a bit tight) and overall very well organized! Well done to Adam :D
Personally I was a bit disappointed at my own result, not so much the number of rwkw's generated but the fact that I was running 1psi off from the tuning 2 weeks ago @ HITMAN. Also, I'm still wondering why they backed off the throttle at that specific rpm - definitely wasn't rev-cut. On a good note, I got a torque graph out of it :D very torquey setup :/
However, just like last time - I've come home with new ambitions (oh my god here we go again)... we've re-routed the boost lines and we're now currently holding 13psi flat :) Dunno if it'll be stable, need to get it dynoed again soon or maybe I'll just wait for the Haltech.
Great chatting with old mates, new mates and most of all seeing the turnout to this event!
Mik made 371kw. Boost is typically 1.45 bar.
Thanks to Adam for organising and John for running. Also, thanks to Ben for finally listening to me and strapping it down... :/
Did STD turbo GTR make more than last years mark of 284 rwkw?
yeah he got 265rwkw with nos, between 4000 and 4200 rpm he went from 120rwkw to 235 rwkw!!!! Near vert curve. Crazy.
It only took that long as I asked Ben from UAS to ramp it slowly to 4400rpm then bury it :/ Not a great idea ramping from low rpm with nitrous on a dyno under load. Rods don't like it. lol
I was happy with the 190kW no gas - I hope anyone who watched the curve or saw the power vs. manifold pressure graph took note of the values. If there are any old pricks with something to say purely for the sake of saying something still talking i'd be surprised.
Thanks to Adam, Turbosmart and UAS for a great day.
Adrian
Adrian
Im an old prick...but have noting but congrats to all the winners!!!
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
