Yeh it would fit just fine. Remember our car has no inner gaurds. I could afford to have the header pipes longer than that still.
Turbine
But Carl is one of the RB20 brotherhood who is ringing the RB20s neck in the US, so i think he was referring to his Silvia beign LHD :D
You cant really tell what the manifolds are made of as it looks to have a coatting of some kind...could be mild steel or stainless steel pipe. Things is it pipe , not tube ...so bigger, heavier, but probably more durable
Could well have been my one?
Or the one from Rons old car which went to SYD  :)
Could well have been, from memory it was back in the early 90's, a red GTSR.
Funny how I still remember that manifold, I think we wanted to fit one similar to the Starion we have.
Turbine
Turbine
Not mine then :P
Sounds like the muppet Fred Bruno who turned a Aus Spec GTS II into a mock-up (4-door) GTS-R and claimed all these big and wonderful things (which were
Horrid car lol.
Speaking of all the talk about GTS-R manifolds, im making enquires now to have it copied through some avenues.
Will advise on the possibilty of this endeavour late next week provided cost is reasonable. Anyone care to throw a figure out there for what they would prepare to pay for a proper job, not some e-bay hock
We would consider one around $500 but it want to be good and a low mount with clearance for a bigger comp cover than standard.
Not mine then  :)
Horrid car  lol.
I use to work at a specialist welding company, and we used a compnay that did awesone one piece Mandrel bending. Had the ability to do quite complex shapes...asll out of one piece. When i had my R31 i looked at getting them to make me some manifolds similar to the RB20DET-R manifold....the 6 lenghts of bent up tube to make the manifold out of the correct grade of stainless was about $900 :P
The to get the flanges laser cut etc...it gets cheaper with volume...but its pricey.
To make one up out of welded sections would be a lot cheaper, but typicall if a tubular manifold cracks it cracks at the welded joint...
Funny you say that Ash as after I made my power figure the tuner put it down to my manifold being a "freak" and suggested the tuning characteristics of it are perfect for gas speed to spool a turbine urgently and keep the gasses flowing high in the rpm range as you well know from your previous setup which was no slouch at all.
He was planning to price up replicas upon my next service but as you mentioned I doubt $500 would cover a decent job. Dont hold out Ash on getting prices as I would love love an external gate version but would not dare hack up my one. The external version posted earlier looks good to me.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
