Hey guys,
Got my car dynoed over the weekend.
Pulled 247.4HP.
Mods include:
3" Turbo back exhaust
FMIC
HKS Pod
12 PSI boost from bleed valve
Im pretty happy with the result....can anybody else with similar mods comment on their dyno result?
Just wanting to compare with others.
Thanks
Stel
Think I would rather a little less HP and a lot safer a/f ratios.
12.5 or so after it has come on full boost is a little lean.
Wind down your boost until you sort out if the problem is injector flow or fuel pump.
BTW , why can't workshops turn the bottom scale from kmh to rpm .
It's not hard and is a lot more useful for comparisons regarding spool up , lag etc.
Cheers
Ken
Check the RB25 dyno sticky thread :)
But yeah, pretty spot on. Long as it drives good, thats all you need.
You need an SAF-C/PowerFC though as you have the typical "dip" in the mid-range, and then another nasty one further up.
Also i'd drop 1-2psi outta it for safety if you arent looking to upgrade turbo anytime soon.
Give it some solid curry @ 12psi and ceramic wheels have flown a few times before
We'll i have an SAFC going in tomorrow so should be fine after a tune with that.
I wanted to see what i get before and after SAFC.
Not necessarily , they normally run rich all things being correct.
I think you still may have a problem with your fuel pump.
Cheers
ken
Thanks for the advice guys.
The guys at Castle hill said that the afr's arn't too bad (between 11-13) but i don't know how interested they where in helping out.
Im gonna install the SAFC, tune it on the dyno, if we see there is a problem there with fuel pump or anything similar ill get it change.
Lets see how we go i guess.
Im not driving the car much now anyway....and i granny shift when i drive anyway so it should be ok.
Thanks again for the help.
Stel
The AFR's are ok. The little stab at the end is where he snaped off the throttle. 12.5 AFR's are good. My only concern with the dyno sheet is that 1. You shouldn't be making that much hp from those mods and 2. It was only an average of 28 degrees in castle hill on that day so what's with the 38 degree air temps. 40 degree inlet temps would see you making much less hp than that with those mods.
Personally I think someone has beefed up the results.
I dont think its a case of "see" if there is something wrong with the fuel pump.
consensus is that there is something wrong, ort something about to go seriously wrong.
Its far to lean for a stock ECU
But its your car, and the experts here have given thier advice.
Take it or leave it really
Yahe, I had 12.5 ratios on the stock ecu after same mods. It was the fuel pump. PSI was dropping to about 40, instead of 51. Tuner said just under 12.5 is about right, but change the fuel pump and get it retuned as the fuel pump will get worse.
Safc won't give you any more power, but will help the fuel trim issues that you get with r33 at cruising speeds. I dont know if r34's have this problem, but I ganied about 130 KM a tank at cruising speeds after tuning.
I run just slightly richer ratios than that and I have a SAFC installed and we have had to take out A HEAP of fuel to get the powercurve to smooth out... unless your ecu has been chipped you have something wrong somewhere!
Also That dip in your top end looks like your ecu is pulling the timing back (for whatever reason maybe related to your fuel pump which has been mentioned ^^)... dip in the middle is normal for stock ecu but it could be better
R31Nismoid is right and there is something wrong with your fuel pump. The AFR's are ok though....for now. They could be a tiny tiny bit better but AFR's of 12.3 ish are fine. With those kinds of mods and running that boost you should have AFR's closer to 11 though....so yeah, unless you have a partially blocked fuel filter....change your fuel pump
Edited by 3lit3 32
Standard ECU should be giving you about 9 or 10:1 AFR at those mod and boost levels.
Check your fuel rail pressure under load. Most likely as they say a fuel pump issue.
Replace fuel filter yourself before you get this investigated.
Any tuner (respectable) will tell you these cars run rich when the wick on the turbo is turned up or mods added. In fact sometimes mods = less performance as more airflow = less timing, rich AFR.
My stock ECU went down to 10:1 AFR at 8psi boost. Power FC went into 9:1 AFR under load at 10psi.
Your fuel pump might deteriorate more so don't let it go too long before fixing it up.
DONT use a SAFC to richen it up. It should be there to lean it out on these cars.
As a side note - I got 172rwkw at 10psi on a conservative dyno (so within about 10kw of your figure). 10psi maybe safer for you.
Edited by benl1981
Hey guys,
Got the car tuned last night at Unigroup engineering.
I have just installed an SAFC and the powergains where very noticable.
Last dyno (first post) pulled out 187kw with pretty shocking afrs.
with the safc i managed to get 206.6kw with an AFR of about 12 flat.
I asked if it could have been a problem with the fuel pump last time and they assured me that if it was the fuel pump, the afrs would be going up with the revs.
The first power curve was just after safc was installed and car was running funny.
cant explain it any other way, only did it once, then sorted itself out.....
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
