did they give any explanation,? or use a different material this time ? I used to do it heaps with my old JB single, got the point where every time I launched even with no riding the clutch it would weld :domokun:
their explanation was the clutch looked to be contaiminated.. or the clutch adjustment wasnt right..
im hoping one of these are the cause....
if it happens again i wont be happy :pirate:
anyone tried out the nismo copper mix single plate clutch? A Few people seem to be running the twin plate version, but i think it is overkill for my needs.
http://www.nismo.co.jp/en/products/competition/clutch/sc.html
If so hows it go? Im looking for a clutch to hold about 300rwkw and the car will see pretty much only street driving so I want something that is as close to the stock clutch in feel and driveability, yet strong.
I use a Nismo super coppermix single plate on my SR20. Rated at 400ps. Relatively easy to use but obviously harder than stock.
You should be fine but I would be careful if you decide to push more power later.
iv been using the single plate in my r33. has 300rwkw and has been in for around 3 years. mainly drifting and seeing alot of abuse. Held up OK considdering how hard i pushed it. If i was to put a clutch in a 300kw car, wouldnt go anything else but a twin plate. Do it once, and never think about it again. But if you baby your car, then the coppermix will be ok.
iv heard of a fair few gearboxes getting broken with these jim berry clutches... How heavy are the clamp loads? are they dampered centres?
I think that only seems to happen when people are dumping the clutch at high rpm on take offs but someone else maybe able to shed more light on that.
a mate of mine had a fully monty in his 370kw r34 gtt not too sure what clamp load but he smashed 3 gearboxes. Then i hear some people abusing the hell out of their cars with twin plates and not damaging a single box.
That is driver related. U can smash a box on worlds softest clutch, yet u can retain a box with a multi plate clutch if u are not rough. I've had a triple, twin and jim berry...I will never go back to a multi plate clutch for the reason that they are too brutal on the driveline and are way too aggressive to drive. The best test, let your girlfriend/wife drive the car :)
im with you marko i cant see how a particular clutch can kill a gearbox its all bout mechanical sympathy imo you flog the ring outta your car and shit will happen regardless of clutch type its just the nature of the beast! My car has a Jim berry standard modified clutch which made 3100lb of clamp feels as light as the standard clutch and is handling 336rwkw fine i drive hard but i dont flog the ass outta my car though and from my personal experience with jimmies clutches its felt better than ANY other clutch hands down from the weight of the pedal to how it bites on take off its a very user friendly clutch indeed
well i just took my car out for a test drive.. fitted an ORC 709 9" disc solid centre hub twin plate.. Have never stalled my car so much in my life and i didnt even get out of my driveway! Not a clutch id recommend for street use at all but there is no time for being soft when its a track car. No more clutch worries :)
Marko & Mick, from a relatively small clutch shop, who specializes in heavy singles, there does seem to be a lot of reported box breakages from JB's ? compared to all the rest of the brands combined, would you not agree?
I'm sure there are equal numbers of people with the other brands abusing their shit. ?
Smashing boxes would indicate the stregnth of the clutch rather than a weakness.
Imo that means they are good, the weakest link is what always fails. Though imo smashed boxes are almost always an issue of driving style.
More issues reported with JB? How on earth could you know, has there been a poll where the values have been normalised against the number of people buying them? This thread is almost soley about JB so unless you have made an excel spreadsheet with number of comments for and against for all brands and worked out the percentage, chances are your view is greatly skewed. More breakages could simply mean more people are buying them, might still be a lower percentage.
OK we'll leave the percentages vs brands etc out, that comment was only based on the amount of times I recall reading similar comments and personal experience, I don't want to argue numbers.
Smashing boxes doesn't show what a fantastic clutch it is, but rather how hard it is on the driver train. From personal experience I didn't change driving style and had never broken a box until changing to a JB 4200lb clamp single,
Anyway wheather it be materials or whatever, there seems to be a huge difference between peoples experiences, some love them say they last ages take heaps of abuse and have no problems, while others like me ( and I tried 2 of them ) found them shuddering heavy hitting and in the end would spot
weld itself to the flywheel every time I'd launch it, and got less than 5000km before rooted, in contrast, with the same driving style I just got nearly 25000km out of a OS triple .
I only give my opinion and experiences so people can make their own educated decision..
that was my point earlier in the piece.
ive had multiplates & imo NOTHING comes close to JB's clutches for strength, driveability & gentleness on the drivetrain.
mine has never shuddered BUT those multiplates ive had would shudder on any rpm - i always felt like i was hurting the car.
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
