it looks fixable, this is the bit i kick myself, because i had the under lying eg the rear shelt etc if they are damaged to replace yours..
we cut the remains of the cut up last weekend to take to the tip..
i do however have pile sof the interior stuff left, so if you need some get in touch with me and ill see ifi can help you out
good luck sorting it, theres a couple of places in the east who should be able to help with panels if you need them
A1 nissan wrecking in qld is where i got my cut from
ADDRESS
94 Musgrave Rd
Coopers Plains
QLD, 4108
Australia
Ph: (07) 3277 8926
Other: (07) 3277 8926
Fax: (07) 3277 9938
Edited by Denver
Damn that looks bad, how did she reverse it so hard?? :) Yeah good luck with the insurance, I hope you had her down as a driver. Good luck with getting the car & house fixed. :)
Thanx for the kind words guys. She wasnt reversing. She was turning right onto willmott dve in rockingham. (not going to fast or anything, witness has testified this) road was greasy and car hit some loose shit. Tail has comeout. She has panicked and hit the wrong pedals. Car has spun a few times and slid backwards up the persons front lawn into thier carport.
Insurance has said that they will cover it. My excess is gonna be $1400 and if it is written off i get first dibs on the wreck. All my mods are covered too which is handy.
  • 4 weeks later...
That looks bad, Just glad everyone is Ok.
It is a sad thing to say, but cars can be replaced...... I would hate it to happen to me, but as long as everyone is safe, there will be light at the end of the tunnel.
Thank goddness for the insurance company covering it
All the best
Mike
Whoa dude!!! thats some nice bingle right there. If nobody is hurt all you can really do is sit back, scratch your head and laugh eh. Make sure u take bulk photos so you can pull em out at the wedding and make some "thick and thin" comment :( I see bully beat the fire truck there.
Hope it works out for you mate. The "its just a car" thing may not be working for you right now but look back on it in a while and you will laugh.
Maybe she needs a minor "how not to freak out while going sideways" course.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
