Just finished reading an article in a commodore magazine that run a test on most of the leading motor oils & the results were a bit shocking.They used a Falex Lubricity tester which is an industry standard for testing oils.By far the best performer for the money was the Valvoline Durablend it outperformed Motul,Shell Ultra & Mobil.
Has anyone used this stuff in there RB.I'm currently running the Shell Ultra but after what i have just read & seen I would prefer to use the Valvoline?
The one thing that stood out in this test was the more you pay doesn't always get you a better oil.also royal purple had the best results i think but is a lot dearer than the Valvoline.
It did appear to be an independent test.
https://www.sau.com.au/forums/topic/103389-oil-test/
dunno they wreckon they supplied said oils & had a labratory conduct the tests with load ratings & pics of a test bush that was used/scored for each oil.the pics & the load ratings suggested would have pointed anyone to either Royal purple or Valvoline!
anyways justed interested to see what u guys thought.
https://www.sau.com.au/forums/topic/103389-oil-test/#findComment-1900204
LOL, So in the said test, did they applied heat, to the sort of temperature range that a turbo motor expose the oil to. You might find the result will be very different. Nothing kills oil of faster than heat.
Well, that what I was led to believe.
https://www.sau.com.au/forums/topic/103389-oil-test/#findComment-1900452
yeh i asked myself the same question when reading the article ,also no tests on the ability to remove contaminents etc.The article had nothing on what temps the oils where at.Can grab the mag from work & post up some of the article if that isn't breaking any laws?
https://www.sau.com.au/forums/topic/103389-oil-test/#findComment-1901583
The best oil test will either be the Sequence IIIG test, timken, HTHS or real life UOA results (used oil analysis).
IIIG
Interesting site for oil analysis (BITOG)
UOA
https://www.sau.com.au/forums/topic/103389-oil-test/#findComment-1905220
I wouldn't ever trust anything in a magazine paid by advertisers.
And what is good for a pushrod, is not necessarily good for a dual cam turbo engine.
I second that... that's pure marketing, i wouldn't trust those mag article either. Ester base fluids like Motul 300V, Redline, Neo and Fuchs Silkolene will be very good for high temp turbo charge engine.
https://www.sau.com.au/forums/topic/103389-oil-test/#findComment-1906908
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
