Hi everyone I really need some advice from you guys.
I have a Series 1 R33 Sedan - the one with the ugly taillights lol.
I'm in the processes of doing her up but I can't get past the lights. Anyway I want to do a conversion to Series 2 taillights.
So basically I want to rip them out and chuck in series 2 ones. Has anyone done this before?
What I need to know is, is it possible?
Thanks
PS. Below are the only two pics that I could find the 1st a series 1 (silver one) and the 2nd a series 2.
http://www.skylinesaustralia.com/photopost.../big/perpage/12
http://www.skylinesaustralia.com/photopost...door/perpage/12
the 2nd one is Impul version isn't it?
Hi no the second pic is just a Series 2 sedan.
Most people hate the back of the R33 series 1 sedan & because the series 2 sedan is so rare, most people do not know it exists.
Rarity - that's one reason why I want to do the conversion.
Jlnewton, you must have one of the only series 2 R33 sedans in brisbane. Good on you they look sweet.
Does anyone know any contacts in the spare parts industry?
I contacted about 20 places on saturday and not one of them has series 2 sedan tail lights. Over half didn't even know that there was a difference between the two series.
It's hard enough finding skyline sedan parts as it is.
Thanks
Try Justjap, they may be able to source some for you.
Thanks chaos, i'll try them in the morning!
Do you know anywhere that would possibly have them in stock? Or if it doesn't take too much time could you please give me the names of the main mobs that you know in Australia?
Thanks
i think its called Alljap aswell, there a wrecker on the northside i believe (not 100%) sure. Justjap are located in Sydney but they always over night their parts etc as i've bought a few things off them.
Also go to the buisness trader section on the forum and ask around there, they may have some or can source some aswell.
Also, the only difference I can notice with the lights is that the blinkers are in a different spot.
Would that be a problem or do you think that it would be easy to get around?
And Chris I'll let you know the end result.
Thanks
I have picked up the lights and the centre garnish today & they are in perfect condition. The car I got them off was a 1997 series 2 40th annerversary special edition and it alsol had a special edition spoiler.
Anyway the spoiler looks great but the guy won't sell it without the boot. My question is would the boot also be interchangable with my series 1 boot?
Thanks
Edited by jcsky2005
Thanks
Yup. Congrates on the find.
There are a few series 2 sedansin Bris. My new one obviously, my old one is still getting around here, and I have seen a purple one, white one, two other silver ones, a creamy/off white one and a dark blue one.
Yeah thanks.
Both lights and the garnish set me back a very reasonable $450.
Dropped in to see my cousin who is a panel beater yesterday and he reckons that they will slot right in no problems. He also quoted me $100 to prep, paint and fit the lights….I owe him one!
So that’s $550 all up. I took some pics yesterday of the back, so I will post the before and after pics when the cars done.
Jlnewton, what year is yours? And did the back/taillights of a series 1 sedan play a role in your decision twice to purchase a series 2?
The car I got them off was a 1997 40th anniversary and the rear wing and stock body kit was simply just really nice. Shame that one side of the car was in bits and pieces, scattered on the side of a highway somewhere because I really liked those skirts!
Mine is a 97 manual. The main reason for going to the series 2 is the battery has been relocated back to the front of the car, same layout as the R34s. Means a much more usable boot space which is the whole reason I wanted a sedan, to be more practical.
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
