that's right..clutches! :)
so it's that time where we find tha a new clutch is what we need in order to keep those gear changes nice and smooth....so how about we all share some ideas on what kinds are out there and what we should be looking at in terms of money to hand over.
im starting this new topic as, you guessed it, i have no ide on what type of clutch to get. how about some ideas on types of cltuches available, price, and applications. im only looking at something like a heavy duty single plate at this stage, but not sure if a brass button would be suitable. have heard that it's considerably better and lasts longer. my car will be street driven (so nothing like triple plate or hyper -carbon compounds needed..though i wouldnt mind one hehaeh :) ) and don't mind if it's heavy on the left foot.....coz my right arm is stronger than my left after some considerable exercise as well lol...hehehehe...aniways back to the topic. WHAT kind of clutch am i to get? and HOW MUCH?.....and WHERE most importantly!
im located in sydeny western suburbs, so would prefer local....but anything throw at me will be considered. :D
https://www.sau.com.au/forums/topic/103920-clutch/
One of my friends just bought an MR2, with a brass button. I have heard many bad things about how undriveable they are, but apparently the previous owners girlfriend learned to drive a manual with the clutch. He also drove it every day. My friend previously had a Telstar (clutch == sponge) and he is having more trouble with the different shift pattern than the clutch.
According to the MR2's previous owner, the trick is in the setup - ie take it to a place that knows what they're doing. I would guess if they strongly recommend one, then they probably know how to set it up.
On the other hand, although it may be expensive to replace a clutch, and a brass button will probably not need replacement, a clutch is designed to be a consumable item. And it's cheaper to replace than your diff/gearbox etc. If you make the clutch indestructible, then it means that something like your driveshafts become the next weak point.
The week after the old owner of my car installed a nice new clutch, he destroyed the diff launching.
https://www.sau.com.au/forums/topic/103920-clutch/#findComment-1910519
hhmm...looking at supporting 250kw atw at the max. decided to go for an Exedy brass button....unless someone can talk me into getting a different one. lol
Ring Jim. He will talk you out of it.
https://www.sau.com.au/forums/topic/103920-clutch/#findComment-1916551
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
