Yep i agree with the above, did wonders for my car once it got off the boat... they have a full cut polish and also a middle-of-the -road one which isn't quite so abrasive, i think it's called a "cleaner" or something to remove dirt/grime and oxidised paint. crystal finish somethingorother. ah heck you'll find it!
https://www.sau.com.au/forums/topic/10417-cut-polish/#findComment-166927
I think its Eagle one hmmmm trying to think but they do the wet shine tyres and their polish brings my car up like glass - ive also got maguires wet shine but it smudges for me - then again some days i just cant be bothered putting any effort in - its like im only doing this because my car looks gun metal grey when it really should be black. All i can say is what you pay for is what u get and if u can grab hold of armoural wipes for the inside of your car - do so! They are like baby wipes but you go over you vinyl/leather dash and steering wheel etc with them and they really do a good job specially if you car is sitting in sun all day.
https://www.sau.com.au/forums/topic/10417-cut-polish/#findComment-167548
Guest KILLER-T
If you have a black car dont even think of cutting the paint work back yourself unless you know what you are doing because it will just end up looking crap full of swirl marks in the sunlight best to let the pros do it but you could try meguiar's scratch-x it works good on black paint and then try some meguiar's gold class wax:uh-huh:
https://www.sau.com.au/forums/topic/10417-cut-polish/#findComment-167757
I tried the turtle wax, with the chip stick... The wax itself is colour coded (just get the same shade as your car, e.g. red, blue etc).
It did cover up a 2" scratch on my boot lid and looks less obvious unless you come very close. I may do it again to get another layer for better protection.
Always a good idea to do it once every few months I suppose, but of course not every week.
https://www.sau.com.au/forums/topic/10417-cut-polish/#findComment-168229
"and if u can grab hold of armoural wipes for the inside of your car - do so! They are like baby wipes but you go over you vinyl/leather dash and steering wheel etc with them and they really do a good job specially if you car is sitting in sun all day."
In my opinion Armourall is rubbish - ie too greasy/slimy, you can always tell if someone has used it. The Meguiars plastic cleaner is better, lasts longer, looks more 'natural' and you wont slide right out of your car.....
https://www.sau.com.au/forums/topic/10417-cut-polish/#findComment-168566
Originally posted by SupaFly Skyline
meguiars all the way
Yepp, that's what I use.
The last time I polished the car was about 12 months ago, and it still looks great after a wash.
Hay one thing - has anyone used one of those electric buffer things that you can buy for $40-50 bucks???
Are they any good??
It would make the job sooooo much quicker.
J
https://www.sau.com.au/forums/topic/10417-cut-polish/#findComment-168569
U know how i said those wipes were amoural they are actually maguires gold class - my mistake why the hell i thought they were amoural is beyond me - they do a good job of the inside anyway!
https://www.sau.com.au/forums/topic/10417-cut-polish/#findComment-173322
i got one of them buffers the other day lol... i'm gonna use it on my black car tommz, I'll let youse know how it goes...
It was on sale in Marlows from $60 to $20 (with a discount coz my mate owrked there).
I now have to find gold class hard wax by maguiars. I use the liquid one and it works wonders but liquid wax tends to fly off the buffer.
https://www.sau.com.au/forums/topic/10417-cut-polish/#findComment-173833
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
