UPDATE:
Spoke to the ****wit responsible for my engine destruction and the Einstein claims that he drove the car from his garage to the storage yard and the car died on the way there. Mind you, this means that the car moves 15 metres, then goes down one ramp for another 15, then does a hard right 180° into another driveway and then up another ramp for 50 metres, then about 15 metres to where it was "stored". All the while you would struggle to drive the car at more than walking pace. He claims it happened going up the ramp and obviously isn't taking any responsibility for the damage.
It was so funny I almost laughed.
Almost.
  • Replies 67
It is without doubt a bearing seized up locking the rod solid to the crank ,something had to give.
I have never doubte that. The car was stopped and towed as soon the bearing knock developed.
it is this mysterious 100m drive that is the issue.
Nick and shif_tea
Only problem there is that he doesn't have any laundry...
ross80, thanks for the newsflash, Captain.
nxtime,
my r33 developed a knock and at first i thought it was a noisy tappet so i was on my way to get some new oil, and it seized.
My bottom end bearing spun and disinegrated similar to yours but my conrod didnt snap (however it was ground out by the ring. The grooves in the block were unrepairable, the crank was f**ked and the head was only just repairable with a grind, which i ended up selling for $800.
My dad is a mechanic and he puts it down to a failed oil pump.
You towed it to this place because you wanted to alleviate any further damage and then he drives the car and it breaks????
In regards to how he might or might not of driven it my best friends built rodeo engine spat a rod out two years ago and car was travelling at about 30km/h on cruise do a bearing being starved so it is possible but its no RB so I guess its irrelevant.
You mentioned it went up a 50 metre ramp, so is it possible that if he took this ramp in too tall a gear that the pictured damage could be the result of the excess load and ill bottom end?
wether he thrashed it or idled it doesn't matter.
you towed it there with a problem, then they DROVE it to storage, it broke.
they are liable.
I say go there, with a tape recorder and say "After I had my car TOWED to you with the instruction that it has a knock sound, what EXACTLY happened from that moment until the time my block got a "speed hole". "
it's legal to record a conversation if ONE party knows it is being recorded.
that be you!
What must be considered is that he CLAIMS that the car was driven less than 100m and died going up the ramp.
Now, my car has been driven up that 45° ramp before and even if you gave it 100% throttle, it will not accelerate hard due to the large cams etc.
The bottom line is what he claims and what actually happened are two completely different things.
GTST, you are correct. It came on a tow truck because it developed a bearing knock. It SHOULD NOT have been driven at all.
But Einstein decided to drive it, and by the damaged caused, it most definitely wasn't driven a few metres up to the storage yard. It has obviously been thrashed.
If u can get him to admit he drove the car at all he will be liable. That fact that u didnt tell him to not drive the car is irrelevant. That would be implied since u had the car towed to the workshop.
Who is this guy btw so i know neva to take my car there!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
